Need Help on Radio
NY
Need Help on Radio
I have a question about this, I have 2 cars 1 has a 27 am and the other has 75 fm and I would like to use the 75 fm on both cars. Do I need to change the receiver on the other car which has 27 am to fm receiver or do I just put a 75 fm crystal on it the same freq. as the other car, I pretty much a newbie here so please bear with me do I need to change the servo too, I don't know please help out. Thanks
RE: Need Help on Radio
The Tx and Rx must be the same band (both FM or both AM), and exact same frequency in order to work.
In your case, just replace the 27 AM with the new 75 FM Rx that has the same crytal freq as your 75 FM Tx. Servo is not needed to be changed. The best is the Tx and Rx should be the same brand name because if different brands, sometimes glitching may occured.
