Please help me(radio problem)
On my sportwerks chaos there is a tinyyy hole about 1mm on the antenna leaving the wires exposed and i have about 1 foot of range now=[[[
Any way to fix/is this the problem?
RE: Please help me(radio problem)
The moment that happen, what were you doing??? How you put a hole on the antenna? It might be that, but i'm not sure. If it's antenna's problem anyway, then you should replace the receiver. But on the other hand, is stupid have 1 metre range. Are you sure? It sounds suspicious
He could of tripped it over and scagged the antenna
You can get some more wire and solder it to the reciever make sure its the same length as the standard one tho
Or try patching up the "hole" by solder and fuse the strands back together < that method depends how much is missing on the strands off course...
Thanks guys,but yeh I was stringing it through a new antenna tube and i got a little out on the end and pulled the rest or the length through and it made a little hole no wire is broken and i don't know what is wrong but i called horizon hobby and they're sending me a new radio set under warenty so its all good.
