3PM-FM settings for RC Electric Drag Racing
Dear Futaba Support,
I need help in determining which adjustments on my 3PM actually affect throttle performance on my Top Fuel electric dragster.
R2E (the car) uses a 3PM-FM radio with R133F FM receiver. Motor is Novak 4.5 HV sensored brushless. Controller is Novak HV-MAXX. Battery Power is Thunder Power 3s x 3850 LiPo. BEC is provided by motor battery with a Novak 'Glitch Buster' capacitor on B/C port of the R133F. I do not use a seperate receiver battery.
I broke the code on the ATL brake setting and can successfully alter braking pattern on the rail to keep from shearing rotor shafts off during shutdown. What I need help with is if and how to adjust throttle. I'd like to 'soften' the launch, then deliver full power beyond the 6ft mark. Can I do this with 3PM FM transmitter settings? How? My controller profile is not adjustable.
Reading the instruction manual, it seems a lot of the settings are for use with nitro, e.g., throttle servos, and will not migrate to use with an electric ESC/Controller. I am digitally challenged, so maybe not really understanding what the manual is instructing me to do. Appreciate any help you can provide. I feel there is performance gain in the 3PM for my car, but don't know how to get it.
Regards,
Regards,
RE: 3PM-FM settings for RC Electric Drag Racing
Hi AHR43,
If you were using Nitro, I would suggest you use Expo-FW, and set a negative amount of Expo to the forward throttle to make the slower response on take off.
When using an ESC, I believe you are at mercy of the Speed control.
It may be better though to have some of the car guys see if they can help you out, so I am going to copy this post over the the RC Car Radio Equipment forum for you.
Good Luck,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
Good Luck,
Krysta
[email protected]
ORIGINAL: AHR43
Regards,
Regards,
Well, that didn't work out too well did it Futaba?
RC drag racing is a niche sport within RC. Not suprised there are no replys. That's why ahr43 went to you all in the first place.
No problem. I'm working it out on my own.
