eurgle 2.4 ghz
#78
MA
RE: eurgle 2.4 ghz
OK, whats the thoughts on this radio? I know it is super cheap and basically a knock off but sometimes knock offs can be as good as the original.
anyways looking at this one, futuba 2pl, and Airtronics mx-sport. all are under 100 bucks, 2.4 ghz... just not sure which is the best way to go.
I guess if someone has any thoughts, or a review (good or bad) it would be helpful.
#79
MO
RE: eurgle 2.4 ghz
ORIGINAL: Enzyme80
The radio does not have that Expensive feel to it or all the extra LED blue lights, but it'll do just fine. If you want to save a Ton of cash I would just go for this radio because of the cheap RX. you can have 8 models ready to go with RX for less than $150.00!!
If you go with the other two models you will be paying a lot more for Extra RXs, and probably less features, or maybe the same ones.
I would buy this radio again.[8D]
#80
TX
RE: eurgle 2.4 ghz
ORIGINAL: T3beatz
my standard futaba walwart charger works just fine...
i would not call this a knock off radio it dosnt look like the helios aside from the wheel and that weird arced hand gaurd aside from that the case is diffrent but agreed go for this radio if you get it from landairrc you get a replace ment warranty if something go pop
#81
MO
RE: eurgle 2.4 ghz
the Eurgle/Flysky GT3 may not be a direct knock off, but you can tell where the factory got its ideas for this radio from... look at the switch/button placement too.
here is one, you can find them everywhere... check ebay or RCU Adds for cheaper ones.... Also the Hitec ones should work too. http://www3.towerhobbies.com/cgi-bin...?&I=LXNK66&P=7
#82
TX
RE: eurgle 2.4 ghz
only gripe on my eurgle , is that when it hits 9.3 volts it starts beeping low battery but its all good also theres a jr mod for it to add up to 30 models , not sure how to do it but it works on the flysky/ turnigy aircraft radios i think i am figuring it out ive alrdy increased the resolution from 1024 to 2048 bit but it is not for the faint of heart literally have to desolder and solder in a new switch chip ,
#83
MO
RE: eurgle 2.4 ghz
ORIGINAL: zeo 1
#84
AB, CANADA
RE: eurgle 2.4 ghz
ORIGINAL: T3beatz
It works with Analog and digital servos.[8D] and you should be able to put an in-line fail safe on it now since the V2 RX are out.
ORIGINAL: Enzyme80
i know on the first page someone said that it does not work with analog servos. I just wanted to check on this before I purchased the radio.
Thanks guys.
Thanks guys.
#86
TX
RE: eurgle 2.4 ghz
yeah my new apmlifier gets kinda hot but its worth it for the reduced latency with my s3300 throttle servo and hitec 5645 digital steering :d using this on my nanda swift 2
#88
MO
RE: eurgle 2.4 ghz
ORIGINAL: zeo 1
try airlandseahobbies, there much cheaper there, 80 bucks with free shipping 20 bucks for the v2 rx's
The radio I got was only $45.00 plus like $23.00 to ship it with EMS express. (branded with flysky) http://www.rc-fans88.com/details.asp?prodid=1636
#89
DE
RE: eurgle 2.4 ghz
[link=http://r2hobbies.com/proddetail.php?prod=rcps61413]Eurgle 2.4MGHz 3-Channel Receiver[/link] is available at R2Hobbies.com for $9.16 + shipping - I think this is the cheapest I found for the EXACT Eurgle replacement for the original Rx.
If you want to buy them off of an eBay site: go to [link=http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&Item=350238738617&Category=34056&_trkparms=algo%3DLVI%26its%3DI%26otn%3D1]Seller=Gemstraveler/Store=RVMShop[/link] At $10.03 plus $3.32 shipping & handling, so they're both about exactly the same.
You can even go to HobbyCity.com and get THEIR own brand or others of the 3-Channel 2.4GHz Rx - my understanding is that this is virtually EXACTLY the same as Eurgle/FlySky/HobbyCity and should all bind with the Tx.
Whatever - at these prices and the fact that the Tx can hold 8 or 10 models (I don't remember exactly) but for a VERY reasonable price you can equip ALL your boats/trucks/cars (whether nitro or electric) without buying another Tx.
In post #62, I pointed out that you could get the Flysky 2-Channel 2.4GHz Pistol Grip Transmitter & extra Rx's if you DON'T need three (3) channels.
Have fun - I've got to go to bed and dream about my need for speed since I can't do it for real right now!
sushi2me/Dave
sushi2me/Dave
#90
TX
RE: eurgle 2.4 ghz
i have to admit this radio still impresses me to this date , ive had koand jr systems that did not feel as good to drive with
also if your using a jr charger like i am , i had to reverse the wirepolarity on the charger to get it to work airlandsea has theupgraded rxs i believe as well as v2 of the transmitter plus theres awarraty but that may be why its a little more expensive imswitching out my 5645 mg servo for a scanner rc unit that has a .10response time same torque same price :d
#91
MO
RE: eurgle 2.4 ghz
ORIGINAL: zeo 1
the reason it cost more from there is because its a U.S. based shop.
#92
RE: eurgle 2.4 ghz
ORIGINAL: zeo 1
#93
AE
RE: eurgle 2.4 ghz
I installed the reciever, programed some functions in the radio and only get steering, no throttle and reverse. I installed this system in a Slash SC 2wd truck. What would cause proper steering but no throttle/ reverse? I also tried switching to different channels and the servo goes crazy so I believe where I have it is right. Help please!! Eurgle 2.4ghz 3ch
#94
MO
RE: eurgle 2.4 ghz
ORIGINAL: plat03busa
#95
MO
RE: eurgle 2.4 ghz
ORIGINAL: edvin
Are you sure??? Only one Corona receiver is v2 according to airlandsea homepage.
ORIGINAL: zeo 1
#96
TX
RE: eurgle 2.4 ghz
im not to sure if its v2 im just going by the fact that mine will shutdown or lock up when the tx is off also if your using the stock slashes esc ive heard it has issues with 2.4 ghz systems im not sure though try different channels and see if it works,also a rebinding may resolve the issue as well to rebind this unit turn off the transmitter turn off your receiver insert the bind plug into the receivers bdd slot turn the receiver on and the red led should start flickering once it dose that turn the receiver off again turn on the transmitter with the bind button pressed, then turn on the receiver and hold the bind button untill the led on the rx stops blinking let go of the bind button and unplug the bind cable and turn um off again and then back on , after that it should resolve the issue
#97
KS
RE: eurgle 2.4 ghz
I've been wanting one of these for a project of mine but the shipping is so high. I can buy one for 20 in an auction but the shipping would be 37 dollars. Then a buy-it now would be 43 and shipping would be 58. Im just mad at how he puts two different shipping prices on the same item. Which why i havent bought one yet.
#98
MO
RE: eurgle 2.4 ghz
ORIGINAL: gonggongboy
#99
AE
RE: eurgle 2.4 ghz
This is an awesome looking product for the price, even though it cost alot to ship. Ican only get 11.6 v out of all the new batteries I have. I will contact R2hobbies and ask them about the V2. They usually respond fast to my questions. I have the Velineon brushless system in my Slash. T3beatz, you are correct about the different TH and ST channels, but how do I change it and make it work? I'am a newbie. Most of what I am learning, i get from great treads like this 1. Lots of knowledge here
#100
MO
RE: eurgle 2.4 ghz
This is an awesome looking product for the price, even though it cost alot to ship. I can only get 11.6 v out of all the new batteries I have. I will contact R2hobbies and ask them about the V2. They usually respond fast to my questions. I have the Velineon brushless system in my Slash. T3beatz, you are correct about the different TH and ST channels, but how do I change it and make it work? I'am a newbie. Most of what I am learning, i get from great treads like this 1. Lots of knowledge here[img][/img]
Also you can go into the display menu to actually see whats going on when you pull the trigger or turn the wheel.
