HOTSHOT RE-RELEASE BUILD!
#676
RE: HOTSHOT RE-RELEASE BUILD!
Check out this aftermarket suspension and wheel kit. You get a choice of either silver or gold wheels. Looks really nice! The gold wheels are on the bottom of the link:
http://www.rccarparts.biz/product_in...1c8c7a1f610838
#677
Here's a video of my Hotshot on the beach with a 23T Tamiya SS motor. It needs a little more horsepower under the hood - I have a Novak Havoc sport system on the way. Next time I'll focus on the jumps more.
http://www.youtube.com/watch?v=HsOvixx1pCA
#678
ORIGINAL: ShoestringRacer
#679
Thanks. Yeah the Hotshot is pretty nice little old school buggy.
The video quality on your Boomerang video was very good, it would make a fine video in the sand!
#680
Yeah I guess. I need to find some good dunes first though, the nearest would be in Wales which is 150 mls or so from where I live.[&o]
#681
Is the suspension still very soft on these like the original?
My friend had one back in '86 and when you pushed it down it would not come back up.
I'm trying to decide between the Hotshot or Boomerang.
#682
yeah the shocks are soft, that's because tamiya provide 'soft' oil in the kit. It's right what you are saying that they do not rebound fully, i suspect this is because the action is not as smooth as it could be because the shock bodies are plastic. The shocks on the hotshot are also plastic and they are only a mono type so IMO the Boomer suspension is the better of the two. However alloy shocks would be the best option.
#687
Why don't you check the facts before you post answers like that? The hotshot comes with alloy shocks and Tamiyas hardest damper oil!
#688
Correct my mistake, they are alloy and come with a plastic type housing/end cap. From what I've read the rear mono setup on the HS is woefully over sprung though and has too many parts which tend to wear out and the whole cantilever system goes sloppy after a while. But it's certainly an interesting design that looks good
#690
I think that the shot looks better, but the boomer would be the better performer probably. The real solution though is just to install the supershot type 4 shock suspension, with some more modern day alloy shocks although when you do this I guess you lose part of what makes the car so unique. I say install the stock stuff and run it till it gets sloppy and then upgrade
#694
First I wanna say killer builds everyone. I really enjoy reading build threads like this one. Now, to my question. Does anyone here know if the red plastic parts in the kit are dyeable? Now that I am hooked on this buggy (thanks to this thread and the awsomely aggressive) I'm seriously contemplating a near future purchase. I wanted to give it a slightly unorthodox color scheme but the red would clash and I don't want to just paint the parts as the paint would probably chip, seeing as it'll be a regular runner. Any info would be greatly appreciated.
#695
Here's my Hotshot Original release kit with old school upgrades.
Upgrades:
* Red Anodized aluminum alloy wheels by Hot Trick
* Dirt Eater off road tires. More grip with 25% wider than stock spiked tires.
* CRP battery door plate/chassis stiffener.
* CRP full ball bearing upgrade kit.
* Tamiya factory upgrade 540 motor.
* 540 Motor heatsink
* Tamiya factory H.P. suspension upgrade kit for the Hotshot.
* Thorp Limited Slip Differential for the Hotshot, Boomerang & Supershot 4-WD buggies.
* Team Tekin ESC model TSC 411P with torque adjustment with battery regenerating. This ESC gave extended runtimes on the track.
Upgrades:
#697
ORIGINAL: 860Crawler
that is awesome man
that is awesome man
#699
<Dirt Bug> Thanks Again!
Try "the bay" for the Thorp L.S.D. I see em popping up for sale at least once a month.
Original Hotshot build #2 with old school upgrades
Upgrades:
* CRP full ball bearing replacement kit
* Tamiya factory H.P. suspension conversion kit
* Tamiya factory Gold plated wheels
* Dirt Eater tires. More grip with 25% wider than stock spiked tires.
* Tamiya factory 540 upgrade motor
* RPM gold plated wheel knock offs
* Team Tekin ESC model G-9 with torque control and battery regenerating.
* Deans H.D. battery connecctor
* Thorp Limited Slip Differential for Tamiya Hotshot, Boomerang, Supershot 4 -WD buggies.
Upgrades:
#700
Here's a Tamiya Hotshot Re-Release kit that's loaded with mods. This leaves me drooling! [X(]
[youtube]http://www.youtube.com/watch?v=-57eN-XtqBk[/youtube]
This is the same dude that made that modified Tamiya Grasshopper re-release into a serious work of art!
