RC Classic Cars & Trucks Have a classic that is at least 15 years or older? Discuss it here!
HOTSHOT RE-RELEASE BUILD!
Old 03-04-2010, 04:43 PM
  #701
DirtBug
DirtBug's Avatar
Default RE: HOTSHOT RE-RELEASE BUILD!
I want late March to come sooner than later!  ha ha ha  I'm gonna put in my order from Tower for my 'Shot, but their site says late March for availability.  I already have the bearings, RC Channel metal suspension kit, You-G aluminum wing, Super Stock BZ 23t motor, TEU-302BK esc, and a Futaba 9252 servo (overkill, I know).  I even have the color scheme in my head as well, classic racing Lotus style of British racing green with yellow center stripe.  I want it now!!!
Old 03-06-2010, 11:11 PM
  #702
gulfstreamI
Here's a few more old school upgrades to add to my original Tamiya Hot Shot build. I found these parts from a bag of stuff I bought from a LHS back in the late 90's marked as "clearance".
Original Tamiya 8.4 Volt Battery holder. Allows you to use a 7 cell "stick type" battery that was available for the 4-WD Tamiya BIG WIG. It also allows you instant access to your battery. No more fumbling around with those tiny clips to remove the battery from the bottom.
ID:	1392454   Click image for larger version
ID:	1392455   Click image for larger version
Old 03-06-2010, 11:26 PM
  #703
gulfstreamI
The problem with the standard three point triangle plastic hub common on the Hotshot series 4-WD buggies is they crack simply from over tightening. Here's an old school solution from Parma, an aluminum hub designed for use with the standard plastic wheels and the aftermarket aluminum wheels by Hot Trick. These Aluminum drive hubs are machined to fine tolerances and are far more durable & reliable than stock. No more fumbling around with those tiny stainless pins to secure the hubs to the driveshaft. No more replacing lost pins from loose hubs. Another plus using this mod is the quick change of tires during race day at the track.
ID:	1392465   Click image for larger version
ID:	1392466   Click image for larger version
ID:	1392467   Click image for larger version
Old 03-06-2010, 11:35 PM
  #704
gulfstreamI
I'm not quite sure if this old school mod will do anything to improve the performance of the Original release Hotshot. It sure does look good though. It's a variable "wing" designed by Trinity for the Tamiya Hotshot. It's made of "duraluminum" and has a variable wing adjustment to gain maximum downforce on the rear tires.
ID:	1392469   Click image for larger version
Old 03-07-2010, 09:21 AM
  #705
860Crawler
ORIGINAL: gulfstreamI
Here's a Tamiya Hotshot Re-Release kit that's loaded with mods. This leaves me drooling! [X(]
[youtube]http://www.youtube.com/watch?v=-57eN-XtqBk[/youtube]
This is the same dude that made that modified Tamiya Grasshopper re-release into a serious work of art!
Yeah that guys got some nice buggies. The independent suspension Grasshopper is insane
Old 03-16-2010, 11:06 PM
  #706
rhowe
any body tell me if these will work? my axle points are wearing very thin!! Yeah Racing (#TA05-015C1BK)
Old 03-19-2010, 09:18 PM
  #707
DirtBug
DirtBug's Avatar
Well as soon as Tower gets them back in stock I'll have a Hotshot coming my way, but I wanted to know what your thoughts are on the Supershot underguard as an upgrade. I have several questions about it. How does it mount to the chassis? I have never seen one installed, so does anyone know if it completely covers the battery cover? (pictures?) And if so, would it require a swing-out 8.4V battery holder like Gulfstream has on his original shot? And finally, what about just makingsome sort ofundercarriage protection out of a sheet of lexan? Any and all thoughts/ideas, please! Thanks.
Old 03-20-2010, 11:37 PM
  #708
gulfstreamI
ORIGINAL: DirtBug
Well as soon as Tower gets them back in stock I'll have a Hotshot coming my way, but I wanted to know what your thoughts are on the Supershot underguard as an upgrade. I have several questions about it. How does it mount to the chassis? I have never seen one installed, so does anyone know if it completely covers the battery cover? (pictures?) And if so, would it require a swing-out 8.4V battery holder like Gulfstream has on his original shot? And finally, what about just making some sort of undercarriage protection out of a sheet of lexan? Any and all thoughts/ideas, please! Thanks.
The Super shot underguard IS an upgrade. As the name itself implies, it protects the bottom chassis from nasty scrapes & scratches. It also adds extra weight to the buggy. I have no idea on how it mounts to the hotshot chassis.
If you look at the SuperShot, it was basically a Hotshot on steroids. It had full ball bearings, a slightly different Wing at the back, new stickers & paint scheme, Modified 540 class motor, Gold plated wheels were and spiked off road tires which were offered optional parts for the Hotshot. The handling and overall performance was the same on a fully modified Hotshot . The 8.4 volt Battery holder was standard on the Super shot and Hotshot II buggy. Using a piece of lexan sheet to protect the battery & undercarriage would be a good idea. [sm=thumbup.gif]
Old 04-09-2010, 11:39 AM
  #709
gulfstreamI
Original Hotshot from 1985. I rebuilt this classic 4WD buggy for the 2nd time a few years back. It has a few old school mods and has the Throp L.S.D. fitted in the rear tranny. I used hex hubs to mount wheels from the Tamiya Manta Ray buggy.
ID:	1414833   Click image for larger version
Old 04-09-2010, 11:53 AM
  #710
gulfstreamI
I fitted this classic 4WD buggy with an early Parma dual shock conversion mount from the late 80's. This dual shock conversion gave Hotshot owners an alternative to the Supershot conversion being offered at that time. Side by side comparison between the two dual shock conversions. The Aluminum shocks are from the Asssociated RC 10.
ID:	1414856   Click image for larger version
ID:	1414857   Click image for larger version
ID:	1414858   Click image for larger version
Old 04-09-2010, 12:21 PM
  #711
gulfstreamI
I also fitted this buggy's front suspension with "dust covers" for the ball pivots. The plastic parts & metal ball wear out very fast when exposed to all that dirt & grime.
I used rubber boots found on the Frog, Blackfoot, Monster Beetle drive shafts. When replacing those torn rubber boots on my MT's usually only one side is torn, so I reused the other side that's intact and cut it to size just enough to cover that exposed ball pivot on the Hotshot's front suspension. While these boots are not dirt/dust proof they are dirt/dust resistant and do extend the life of the Hotshot's front suspension components. The last pic shows the exposed ball pivot on my shelf queen Tamiya Hotshot Buggy.
ID:	1414861   Click image for larger version
ID:	1414862   Click image for larger version
ID:	1414863   Click image for larger version
Old 04-09-2010, 01:11 PM
  #712
gulfstreamI
Back in the day before the re-release of the HotShot the front suspension parts were difficult to replace as these were the first to be sold out at the LHS. These simpler driveshafts were then the next best thing to replace the "over engineered" half aluminum, half metal drive shafts the Tamiya engineers came up with.
Another part that was difficult to find back then was the front bearing/pivot housing. So the alternative for me was to use the Tamiya TA-02 part that was also moulded in red color. It is angled slightly as shown in the pic and is a copy of the Tamiya Boomerang which was moulded in Blue color.
Advantages of using the TA-02 steering hubs:
- Can be used with the long replacement drive shafts (Part # 5299)
- Alternate choice of wheels using hex drives.
Good thing Tamiya came out with the re-release version. Now replacement parts are easy to find!
ID:	1414872   Click image for larger version
Old 04-11-2010, 11:38 AM
  #713
gulfstreamI
After a few test runs I noticed the LSD on my runner/beater Hotshot was giving "too much slip". I decided to rebuild the Thorp Limited-slip ball diff after no adjustment could cure the problem. The original Thorp pressure plate was worn "paper thin" and original replacement parts are difficult to find. So now I had to replace it with a similar pressure plate from Robinson Racing that has a simplified version of the Thorp LSD. I re-greased the ball bearings after checking them for wear and assembled the LSD as before.
ID:	1416092   Click image for larger version
ID:	1416093   Click image for larger version
ID:	1416094   Click image for larger version
ID:	1416095   Click image for larger version
ID:	1416096   Click image for larger version
ID:	1416097   Click image for larger version
Old 04-12-2010, 08:56 PM
  #714
gulfstreamI
Installed dust boot covers on both front and rear drive shafts on my shelf queen Hotshot. I am unable to install these dust boot covers on the front inner drive cups due to lack of space.
ID:	1417073   Click image for larger version
ID:	1417074   Click image for larger version
ID:	1417075   Click image for larger version
Old 04-26-2010, 04:02 PM
  #715
DirtBug
DirtBug's Avatar
Finally!! I just ordered my Hotshot from Tower and I can't wait to start building! I now already have a nearly complete "parts" 'Shot that I've built up from a bunch of new parts I gathered here and there. I figured I wanna beat the piss outta this thing so why not stockpile a messload of parts for it. Hey gulfstream, I love the rubber boots at the drive joints. I was thinking of doing something like that myself. RC Channel has the boots for sale on their site, 8 boots for $10 plus shipping (a little pricey). I've looked for the Frog boots you used but can't find any. Maybe I'll hafta fork out the cash.
Old 05-09-2010, 08:50 PM
  #716
DirtBug
DirtBug's Avatar
Finally got my Hotshot and built it up. This is my first 4wd buggy and I love it! It's decently fast enough for me with the Super Stock BZ motor, though the motor gets a little hot second battery in. I'll hafta put a heatsink on the motor to keep temps down. And as can be seen in the pics I already had a collision mishap to the front end, but I'll bend it back. And the paint job came out kinda crappy cause tha can of yellow I had came out like lumpy gravy, but oh well, it's just paint.
ID:	1433680   Click image for larger version
ID:	1433681   Click image for larger version
ID:	1433682   Click image for larger version
Old 05-18-2010, 05:14 PM
  #717
DirtBug
DirtBug's Avatar
Well I'm gonna put up some more pics causeI love this car! Also, the RC Channel susp. and steeringkits get the job done and just look Badass!! I am sincerely unapologetic to the purists who think I ruined the car by removing its quirky, over-engineered monoshock setup. Ha ha ha. Nah, just kiddin.
ID:	1438512   Click image for larger version
ID:	1438513   Click image for larger version
ID:	1438514   Click image for larger version
ID:	1438515   Click image for larger version
ID:	1438516   Click image for larger version
ID:	1438517   Click image for larger version
ID:	1438518   Click image for larger version
Old 05-19-2010, 07:05 AM
  #718
kaiser01
your hotshot is kickass!
i need one of these. i love tamiya 4wd buggies.
Old 05-19-2010, 09:03 AM
  #719
DirtBug
DirtBug's Avatar
Hey thanks kaiser. This is actually my first 4wd buggy and I love it. I've had several Tamiyas over the years; a Rover Mini Cooper back in '96, a Dyna Blaster, andcurrently a Bronco CR-01 and a Buggy Champ. I know it's no racer, but I am surprised how fast it is. But then again all I have to compare it to is my older cars which were all powered by the stock silvercans, a crawler, and my sport tuned powered Buggy Champ.
Old 12-07-2010, 08:34 AM
  #720
coxbros
coxbros's Avatar
I havent been on here in a couple of years, nice piece, I got that suspension kit also but hasnt been off the shelf since, Best car ever with that kit, until the news of the Avante that is.
Old 12-07-2010, 02:08 PM
  #721
gulfstreamI
ORIGINAL: DirtBug
Well I'm gonna put up some more pics cause I love this car! Also, the RC Channel susp. and steering kits get the job done and just look Badass!! I am sincerely unapologetic to the purists who think I ruined the car by removing its quirky, over-engineered monoshock setup. Ha ha ha. Nah, just kiddin.
Your Hotshot looks great! [sm=thumbs_up.gif] Now all you need is that steering modification to eliminate that dreaded "bump steer".
Here's a few updates I made to my Vintage Hotshot.
Fully adjustable camber suspension arm made by Parma intended for the Tamiya Fox but can be used on the Hotshot.
ID:	1531464   Click image for larger version
ID:	1531465   Click image for larger version
Old 12-07-2010, 03:27 PM
  #722
gulfstreamI
Added an original N.I.B. Supershot under guard . Here's how it looks ...
ID:	1531489   Click image for larger version
ID:	1531490   Click image for larger version
ID:	1531491   Click image for larger version
Old 12-07-2010, 07:30 PM
  #723
Striker01
Nice part there, would be nice if tamiya re-produced them for those that wanna maintain the perfect finish on their new re release hotshots. Where did you get it?
Old 12-07-2010, 08:19 PM
  #724
gulfstreamI
Thanks. I got it from a hobby shop closeout sale. Getting A NIB unused under chassis skid plate is still available at "flea-bay".
Old 12-07-2010, 09:17 PM
  #725
Striker01
Overall, how difficult is it to build this kit?
