WING SERVO MOUNTING?
NH
it works but may I suggest that you wrap the servo body in tape and epoxy it into that hole. The tape is to allow you to remove the servo easier if the need arises. The pressure method only works for a little while because hard landings , much less dirt naps, will cause the hole to enlarge when the foam compresses causing the servo to be able to move instead of the control surface.
Just a thought,
JESTER-
Just a thought,
JESTER-
TX,
I use the 100% silcone glue, same stuff as used in bathroom showers, etc.. Its more flexable than the epoxy, so it will give alittle bit. But its not soo flexable that you have aileron slop
