Go Back  RCU Forums > RC Airplanes > RC Combat
 Lanier engine >
Lanier engine
RC Combat Discuss rc combat planes, techniques and strategies here.
View Poll Results: A poll
Thunder Tiger Pro .25
33.33%
Norvel Big Mig .25
66.67%
Voters: 9. You may not vote on this poll
Lanier engine
Old 05-09-2004 | 06:11 PM
My Feedback: (-1)
Default Lanier engine
I'm going to purchase a Lanier Ripper (or is it Slasher? I don't know the name, it's the bigger one). From the two engines listed, and only the two engines listed, which would be the best power plant for this plane? Thanks.
Old 05-09-2004 | 06:34 PM
Default RE: Lanier engine
May I ask why only these two engines? There are better engines available than either of those.
D
Old 05-09-2004 | 06:41 PM
My Feedback: (-1)
Mainly because they are in stock at my LHS, and they have a good price on them. May I ask what you suggest, keeping in the $65.00 price range? Thanks.
Old 05-09-2004 | 07:18 PM
My Feedback: (21)
Check out the Magnum 28XL. It's in your price range. Read the posts concerning prepping for combat. Also keep an eye out here in the classifieds and on the "other" auction site. A good used 25FX can be had for around $50.00.
Old 05-09-2004 | 07:25 PM
The OS 25FX is a bit more, but worth it considering there is alot less fussing with it. They run good out of the box and don't require the "prep" that the Magnums do... The Norvel's are VERY light and put out alot of power, but some have more troubles that others getting them to run reliably. I have a couple of Norvels, and I'm real happy with the performance and they haven't given me any problems.
Old 05-10-2004 | 10:37 AM
Between the two you list, the Norvell is the one to go for. The TT is under powered.
It's no accident that you don't see the top guys flying the TT pro .25 at the big contests.
Engines you do see most often (in no particular order, and I might forget something)
Norvel (both BB and Big Mig)
OS FX
Irvine
Webra (new engine, MAJOR power)
Mag .28 (but ignore the .25, it's underpowered, and over weight)
Jett .30 (less common, expensive, but hard to beat)
Whatever engine you get, you'll want a mousse can or ultrathrust muffler to go with it. It's cheap and easy power.
Old 05-28-2004 | 10:37 PM
I've always wondered if the TT Pro woudn't make a good, fast engine once given the same treatment given to the Magnum. Never actually gave it a try because it was more expensive than the Magnum. Is there a .28? Same deal with the Norvels - their .061 is fantastic value for money, but their .25 was a bit too much money for me.
Old 05-29-2004 | 01:08 PM
Hi,
Any of you guys have any comments/experience re. the MVVS .28? (with the one-piece mini-pipe).
Sorry if I'm confusing the issue
Blue
