Go Back  RCU Forums > RC Airplanes > RC Combat
 need help2 >
need help2
RC Combat Discuss rc combat planes, techniques and strategies here.
need help2
Old 02-17-2005 | 06:57 PM
Default need help2
HI all
i was wondering if this type a plane needs a cg like a wing or normal plane
[img][/img]thank you hayk
ID:	230775   Click image for larger version
ID:	230776   Click image for larger version
ID:	230777   Click image for larger version
Old 02-17-2005 | 08:14 PM
Default RE: need help2
You need to extend your elevons further to the center of the wing into the prop wash for more elevator authourity at launch. Cg needs to be 2.5" with 1/16th reflex and it will fly.
Old 02-17-2005 | 08:25 PM
the plane has an elevator on the v tail i am not going to use the alerons like elevons, but i guess i can mix it in to the radio to have it on the swich, i just needed to know if this plane can be viwed as a normal plane or a wing?
thank you
Old 02-17-2005 | 10:13 PM
...............that is a wing.
