Fun Combat Pic
Administrator
My Feedback: (12)
You're seeing it as it happened! The wing was about 100 yards away. After gathering the fuselage and wing, the pilot got some new rubber bands and put the wing back on, cleaned the dirt out of the carb, put on a new prop on, and continued in the next heat.
Hey cool pic. Is that a FNS? (Friday Night Special). I'm sure you know what I'm talking about. If you dont, check out spadtothebone.com It's a great website. Im putting together a FNS, can't wait to give it a try. Spads rock! If I don't like the FNS I'm only out three bucks.
Take some hight test wax string, or fishing line and attach one side to a wing dowel, and the other side to the wing. coil up about 10 feet of it and tuck it inside the fuselage or neatly under the wing rubber bands...next time your wing gets ripped off...the fuse and wing will stay together and tumbe down harmlessly. May even save the prop and you won't have to clean the carb!!!
Administrator
My Feedback: (12)
ive been tying a string to to the engine ,needle valve reciever and battery then to the fuse on my gremlins, seen too many guys out in the field looking for hours for lost gear.
Hey I resemble that remark...
However that metal detector made finding my needle valve and your .28 alot faster.
