RE: Gremlin help
hey Guys. I feel the love!!
What I do to keep the plywood from splitting is after I drill it all out I soak the holes and edges with thin CA which soaks in and hardens it. What ends up happening then is the PVC lets go so then I take either a 1/8" ply and duplicate the mount and sandwich the fuselage in between them. The other thing that helps is to have a predrilled replacement in your flight box. Since I did that I have never broken the plywood at the field, and duct tape can hold the fuse together for that "one last round" BTW: This month is the 20th anniversary of the publication of the RCM Construction article. My phone started ringing 11/8/1992 when the December 92 RCM issue hit the subscribers. it was almost 2 weeks later before i got a copy or three off the newstand |
RE: Gremlin help
ORIGINAL: Mikie 1 ...but I use 3/8 inch aviation plywood as in the picture.... Mike ORIGINAL: coreman ...The other thing that helps is to have a predrilled replacement in your flight box. Since I did that I have never broken the plywood at the field... <br type="_moz" /> |
RE: Gremlin help
That thing must have been crazy with that Jett engine !
RE: Gremlin help
1 Attachment(s)
I now mount all my gremlin motors this way. They have even serviced a lawn dart. I got tired of making mounts.
P.s. .46 work just fine |
RE: Gremlin help
ORIGINAL: rcplanes711 I now mount all my gremlin motors this way. They have even serviced a lawn dart. I got tired of making mounts. P.s. .46 work just fine |
RE: Gremlin help
I've purchased many feet of the PVC pipe and made quite a few Gremlins the way I showed in the photographs and have never had a problem with the mount.
Coreman - I do like the idea of a "sandwitch" of plywood underneith the fuse. I'll try it next - if I start having problems. Thanks for the idea. brnrbbr - It was a BEAST!! ...and noone wanted to "Play" with me...? Mike |
