Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Drag Racing
 ERC fabrication's FWD honda(in progress shots). >
RC Drag Racing For all you straight line enthusiasts. Discuss all aspects of rc drag racing here!
Old 04-24-2010 | 08:16 PM
Default ERC fabrication's FWD honda(in progress shots).
Here is an update on the ERC fab's FWD Honda. Car is based of GMS's pro stock.
Eric
ERC fabrication
Old 04-25-2010 | 02:58 AM
Default RE: ERC fabrication's FWD honda(in progress shots).
imlooking forward to seeing more. always been a honda fan. i own a 91 crx si w/ b16a now....
Old 02-08-2011 | 02:10 PM
Bob-Stormer's Avatar
What became of this?
<-interested in having a little one that matches our full size "Stormer Hobbies" drag car.
Old 02-18-2011 | 11:40 AM
I still have it. It has taken a while to finish it because I have had no time to dedicate to it. However it will be done soon and it will be sent to San Antonio for testing.
Eric
ERC fab lab
Old 02-18-2011 | 11:46 AM
Eric
ERC fab lab
Old 02-26-2011 | 10:40 AM
waste of time with the rear steering for drag
Old 02-26-2011 | 11:48 AM
studysession's Avatar
ORIGINAL: flaco123
Maybe I am not seeing it right. How do you see the steering in the rear? I do not see any servo installed in the pick and it looks as if the rear wheels are on the motor pod.
Old 02-28-2011 | 08:25 PM
Waste of time? Please since you know so muchFlaco enlighten us all with your reason why it will not work? Did you already try it?Pleaseexplain yourself and back it up with straight facts based on your comment and I will gladly listen. I am willing to listen to a more logical idea that is based off simplicity. Forklifts seem to do quite well steering from the rear but let us see how it does on the track shall we before we end up making comments that could end up with a mouth full of foot(LOL).
Eric
ERC fabrication</p>
Old 02-28-2011 | 08:58 PM
It does steer from the rear . It now has a solid piece of carbon fiber where the servo mounts are installed and plenty of room for the receiver and data logger. The motor pod isreversed and mounted in frontactually like the real car andtraction is provided by a GMS T-BARand a reversed traction rod.Front drive axle is works like a spool which supposed to spin the tires equally. If in theory they do spin equally thecar should not have to use thesteering all that much becausethetraction of the front wheelsshouldpull the car nice and straight.If it works great ,if not I will be the first to say it not the right way to do it. I will wait till the car runs before I make an hasty judgement. I will let the car do the talking.
Eric
ERC fabrication
</p>
Old 03-06-2011 | 07:28 AM
ORIGINAL: erc fabrication
Eric
ERC fabrication
</p>
in theory...indeed. But there is more to going straight in drag racing then just the drive wheels both turning equally. I think the problem with rear steering is gonna be making any kind of corrections after it leaves. Being electric... that thing is likely to hit the tires very hard, unless you will be using a programmable esc where you can soften the hit a bit and control the rollout.
Getting the car lined up in the groove correctly, and just how hard it tries to hit the tires, and what it does 20-30ft will play a big roll in just how straight the car actually goes.
I like the project though. What kind of times are you shooting for?
Old 03-09-2011 | 12:32 PM
I am running a programmable ESC with a data logger. My first goal is what you are talking about wich is to get the feel for the carand work on getting it to goin a straightline and then add power in stages as we go.
Eric
ERC fab
Old 03-09-2011 | 06:27 PM
sounds like you are on the right track then. Im curious...did you go with rear steering for the simple fact of front steering being too hard to do with the the chassis combination being used?
Old 03-16-2011 | 02:27 PM
looks good make a video of the run when it is complete
Old 04-18-2011 | 06:04 AM
looks to be a good idea.....
But just some advice. I drive a forklift from time to time...not a big one its a 6ton forklift, but its got a 2.4d toyota engine, so its got ample power, it also has a 3speed box, and from experience, if you run it at 40km/h (dunno how much it is in miles) and turn it, it wil throw you into it. we have managed to almost tilt it at one time.
So for a safety feature(for the vehicle) the manufacturere installed a device that once you go over 10km/h and turn it as per normal, the turning happens slowly and controlled.
So...have a look into it, so that your servo maby turns slower than normal and not as fast and with the normal "jerk" action.....oh......and set your bateries a bit to the rear for back weight, otherwise youre back end will start to look like a kite on top speed.........
Old 11-10-2011 | 01:56 AM
Been a few months. How'd it all turn out.
Old 02-07-2012 | 02:49 PM
Irlsh's Avatar
yes i would love to see an update to this!
Old 02-14-2012 | 06:52 PM
no matter if its theroy or what ever rear steering just seems really wierd and would look funny lol i wouldint doubt that it may work but arguing your forklift comment about it steering from the rear..you dont happen to see forklift's at drag tracks now do you....iam just saying lol
Old 03-16-2022 | 05:49 AM
Irlsh's Avatar
eric you still around?
