Help !! braking problem
Hi all, i apologize if i posted onthe wrong area,
anyway i have a Hpi sprint 2 drift ,i took out the stock engine and esc and mounted it on my redcat racing,
now my problem is when i drive my redcat racing and position it for a drift when i hit a slight brake it jerks back braking completely and then it stops for like 3 seconds then ucan drive it back again.
anyone knows what this is? thanks
what about your esc?? did you change the esc as well or just the motor?? if you havent changed the esc then maybe it is a compatibility issue between motor and esc?? or maybe the esc you have now on the redcat is not set up properly to read 'idle, forward, reverse' positions.
GA
ORIGINAL: ranz420
but the gist is still the same, i think his throttle positioning is off.
