Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Drifting
Reload this Page >
weird problem I think with the front diff !!! NEED HELP
RC Drifting Discuss all aspects of rc drifting here!
Old 03-15-2014, 06:27 AM
sos52
Exclamation weird problem I think with the front diff !!! NEED HELP
Hello every body ... im new here and this is my first post here
so my problem is really weird that when im drifting with my mst xxx-d vip every thing is OK until I pull the throttle to the end (top speed) and turn to the right (only when turning right and full throttle)
The right wheel stop runing like the car is only 3 wheel drive . Its not stuck but dosnt conect with the diff ...
BTW I checked the diff and every single thing is really fine and super fine and its new and just start acting like this after a month before that every thing was normal 4WD and the diff is alum one way
and also its come back again 4wd after I totally stop the car and start over its start as 4WD but only when i go top speed with right turn thats happen ...
so dose any one had the same problem ?!!! Please I need help
Old 03-17-2014, 01:25 AM
Next edition
Any clicking noises-does the wheel still turn properly when you hold the car off the ground and throttle it.
Old 03-17-2014, 04:10 AM
sos52
Yes BUT only when I turn left and right to the end and the tires are shaking a lil bit also only when I steering to the end left and right
Old 03-17-2014, 10:43 AM
Next edition
Im not sure without looking at it maybe the steering angles to much on the right side and locking up wheel transfering most of its power to the left.
Manually turn car to the right and spin wheels with your hand and see if theres any binding or shafts are spinning in there cups,cant be to much wrong with it.
Old 03-17-2014, 11:09 PM
sos52
Ok I got it now
the problem from the one way diff thats the small threads inside the diff which is grip the joint when driving eroded
I ordered another's one now and after I install the new one I will let you know
Old 03-18-2014, 12:03 AM
Next edition
Cool sorted.
