RC Drifting Discuss all aspects of rc drifting here!
drifting RS4 Nitro 3
Old 05-24-2004 | 11:50 AM
DKD
Default drifting RS4 Nitro 3
ok iv just seen a video of drifting and wanna do it realy bad but i have a mt so im going to buy a RS4 Nitro 3 just for drifting. wot wanna know is wot will i need to get my RS4 Nitro 3 to drift (gear ratio, tyres, suspention setup ect)
thanx
Old 05-24-2004 | 12:26 PM
newbie003's Avatar
Default RE: drifting RS4 Nitro 3
you will just need a abs pipe or a pvc pipe also get extra clutchs incase you melt the other ones.......
Old 05-24-2004 | 06:17 PM
and get the drift tires from yokamos new drift car
Old 05-24-2004 | 06:56 PM
The thing is they get worn out really quickly even with electric, so with nitro, they probably would wear own within a run or two.
Old 05-26-2004 | 07:30 PM
ABS (black) pipe will last a LONG time, but you won't have the speed or quite the same control as you would with the yokomo tires. ABS is also dirt cheap
Old 05-31-2004 | 10:36 PM
becareful if you make drifter, i made some for my yokomo gr-4 and i almost over revved the engine because there was no traction at all
Old 05-31-2004 | 10:37 PM
i ment *drifters*
Old 06-09-2004 | 01:59 AM
ko's Avatar
ko
dont be scared to over rev, HPI motors are strong and durable they can take it trust me...
if you are gonna use rubber or hard foams:
set up a stiff suspention stiff springs, heavy shock oil, thick sway bars, hard rubber or foam compound tires and your set
for ABS or PVC:
thats all you need
