RC Drifting Discuss all aspects of rc drifting here!
new to drifting
Old 07-28-2004, 11:06 PM
delphiindydriver
Default new to drifting
what do yuo use to drift..what are some pointers, good sites,, etc
Old 07-28-2004, 11:16 PM
frozen
frozen's Avatar
Default RE: new to drifting
Use a 4WD car and read the thread on tires and how to drift.
Old 07-28-2004, 11:17 PM
delphiindydriver
why 4wd? i though drifting is no traction?
Old 07-28-2004, 11:24 PM
frozen
frozen's Avatar
Dunno, I read somewhere its alot harder doing it 2WD.
Old 07-28-2004, 11:26 PM
delphiindydriver
whast this i hear about tape and pvc?
delphiindydriver
wait..i asked you that already
Old 07-28-2004, 11:27 PM
frozen
frozen's Avatar
Dunno, I've been to lazy to go look for myself I think you just take the normal rim, electric tape it then put some special white tape on it, if you figure it out, lemme know. AIM Deity of Cold
Old 07-29-2004, 12:06 AM
mtrchamp
ok.... answers:
Why 4WD? Because there is more power going to the front. On a real car, all the wheight is in the front cuz the engine so it keeps the front weight down and in the lead of the rear tires... with 2WD cars the motor is in the back so it is harder to get the front of the car into the drift angle and such, you'll just doughnut...
I Though Drifting was no Traction? It is, it's just the fact of being able to have some traction to control your car, otherwise it's like a plane in the air where you are screwing witht he Yaw effect... more steering, less power, oppisite will make you go another way, w/e
Tape and PVC? People use a number of things on their tires as opposed to foam tires or rubber compound tires. The lasts through about 2-3 runs before you have to change it out, the PVC and ABS piping go directly on the rims like a tire. PVC is white and has more traction... ABS is black like a tire and is the best you can get... like $7.00 for 10 feet of it! It's well worth it....
Hope this helps!
Old 07-29-2004, 02:05 AM
delphiindydriver
thank you
Old 07-29-2004, 02:36 AM
WhiskyVR-4
[link=http://www.rcuniverse.com/forum/R%2FC_Drifting_FAQ/m_2033920/tm.htm]http://www.rcuniverse.com/forum/R%2FC_Drifting_FAQ/m_2033920/tm.htm[/link]
we need a revival of the long-lost art of using the "search" button
Old 07-29-2004, 01:23 PM
HPIRS4-3SS
HPIRS4-3SS's Avatar
it has less traction, because PVC is harder then ABS
ABS has more traction
and yes people do need to use the search button
Old 07-29-2004, 05:08 PM
ajisup
ajisup's Avatar
I just tried drifting my RS4 3 after reading this thread. It seems pretty fun if you learn how to control it. What I did was cut off the bottom end of some pepsi cans and slip them on my tires. It worked well for about a minute. Then one of the cans came off and i got pissed. I threw donuts until the rest came off. So, if you want, you could try pepsi cans on your tires. But make sure they are taped or strapped on somehow or else it will come off.
Old 07-29-2004, 10:35 PM
mtrchamp
It has more traction then Electrical tape is what I meant...
Old 08-04-2004, 08:39 AM
RC-Drift UK
RC-Drift UK's Avatar
Tape is used over trued down foams and works great on carpet, it's ok on a prepared tarmac but normal road/carpark tarmac is usually too rough and rips it after about 3 or 4 runs
ABS is softer than PVC and a set made of 2mm thick pipe will last about 6 hours - NOT 3 runs - Yokomo Drift rings last about 3 runs
4WD is best because all 4 wheels are fighting for traction exactly like ice rallycrossers you see in Europe, our Drifters look just like these round a corner
Here's a tutorial on how to make ABS or PVC RC Drift tyres
Old 08-13-2004, 11:26 AM
abrahim_36m1
if u use 2wd u will spin out that y u use 4wd because all the wheels are spining
Old 08-13-2004, 02:09 PM
spareanychange
back to the 4wd thing, if you have a 2wd car, yes u cant steer but also there is alot of friction between the floor and tire so it will just donut, maybe a little powerslide at best, its all about spinning the wheels to get rid of friction. i hope you get that, im not very good at explaining things to people who dont understand
