RC Drifting Discuss all aspects of rc drifting here!
Drift setup?
Old 02-12-2005 | 06:54 AM
BodyTuner's Avatar
Default Drift setup?
I have Robitronic ETC Sport.Its shaft driven car.I need some info on how to setup it for good drift.I use normal radial tires.Sometimes I use electrical tape.I will put abs soon but I see that it can powerslide on this tires and do spins in circle or even 360 while going fast.I need some info on how to setup my differentials,shocks,chamber and all I need to make it drift good on electrical tape and more powerslide on normal tires.Here is some info on the car.
• 4WD Shaft Drive
• Ball Differentials
• Blue Aluminium Shocks
• Blue Aluminium Drive Shaft
• Ball Bearings
• Rear Sway Bar
• Pivot Ball Suspension
• Adjustable Caster
• Adjustable Camber
• Adjustable Toe In/Out
Width: 189mm
Height: 91.5mm
Lenght: 380mm
Wheel Base: 259mm
Gear ratio: 2.85
Ground Clearance: 5mm
And what motor is the best to use for drift.I have 2 motors.Stock motor acme racing and modified peak racing jaguar 17x2
Old 02-12-2005 | 10:34 AM
sixtoes1313's Avatar
My Feedback: (7)
Default RE: Drift setup?
for rubber tires, seems like you would need a lot of torque to break them free easily. go for like a 19t for mor3e speed, or 27t for more torque. the monster stock is a great motor. but for insane speed/torque from a 27t go for a putnam, or surge tuned motor. THEY ARE GREAT!
http://www.putnampropulsion.com/putnam_stock.htm
http://www.surgeworldwide.com/product_motors.html
for set up, i really dont know, try hard springs all around. since soft in the back usually gives you more grip.
Old 02-12-2005 | 07:54 PM
i use my hpi pro 2 with radial tires and a 16T SPEED JEM motor. I have no problem loosing tracking and doing doughnuts while going at a very high speed. to me i think that you should stick with your set up because if you can get your car sideways then thats all it matters-Juhnk
