RC Drifting Discuss all aspects of rc drifting here!
nitro
Old 08-25-2005 | 07:57 PM
Default nitro
what kind of maintenance does a nitro car require engine wise, cuz i herd they pain in the @$$. i was thinking of getting a nitro TC3 but then i herd this,how true is that.[sm=confused.gif] please reply and
thank you in advance.
Old 08-25-2005 | 08:43 PM
Default RE: nitro
ok nitro cars aren't a pain unles your a very bad drive and crash it alot. but if you don't a nitro car isn't that bad to have. but you need mo0re time for it. break-in . and buying nitro and AA battery eater other than that you get a fast car .mostly faster than any rtr electric car i think. the engine is depended on how you break-in your car . if you break in your car on the instruction you would be fine but if you do it by your self and with no friend who has 1. it will be hard. go to yourlhs local hobby shop and ask questions alot. then if you have trouble get the nitro engine dvd.teaches you how to do many things with the engine and your car. i have 1 and its really helpful. done with that.
ntc3 is a very very good car. but now most cars have electric start which the ntc3 doesn't have. and most people said its better but not me . no more blisters but some think its more helpful and sumtims it is. i have a ld3 2 spd powerstart for a great price and its great. most engines last about a good 2 and a half to 3 and a half gallons of nitro. no matter how good you treat your engine.
Old 08-25-2005 | 09:09 PM
Default RE: nitro
ORIGINAL: gogita502
[X(]that SUCKS!!!! how much are the engines? are they easey to put in? and how long does a tiny gas tank like that last u?
Old 08-25-2005 | 09:34 PM
Default RE: nitro
I have had my jato for 3 or 4 months and I still have the same gallon of gas that I bought with the truck
Old 08-25-2005 | 09:35 PM
Default RE: nitro
okokok the engine depends on your likings. good thing mine is only 54.99 on a website i no. i love my ld3. ok for a good engine get ready to spend 75-100++ upto 250 and over for the nova's very very very very good engines but you dont need them. an hpi t-15 is good laso 1.4or.5 hp is good enough for 75 dollars. to put engines are well again depends on car. you can do it your self. but you must put everything back to where it came from. only thing you need to do is unscrew some bolts and put the other one on and replace the muffler. but dont mess with anything else like gears. you can slide it out if done correctly. then again you can rebuild your engine which is cheaper but i like to break -in a new engine. and rebuilds here in ny most hobby shops dont do it but a dvd on how to- on nitro engine shows you.replacing the piston, connecting rod, and sleeve is what a rebuild it and must me brokin in again. easy to me.
a tank of gas in my car driven regularly last about a good 15 minutes or driven hard 10. on a very full tank. a gallon of fuel should last you very long tho
sry for the low responce hope you think its helpful.
Old 08-25-2005 | 11:10 PM
Default RE: nitro
ORIGINAL: gogita502
yeah man this is very helpful thanks. so i gues buying a new engine is better and faster to do right. when you say replace the muffler that means buying a new one?.
Old 08-25-2005 | 11:19 PM
Default RE: nitro
sry no it just means you have to put your old muffler on.or put a better 1 for more power
and for the engine wise. diffs on the engine like the traxxas 2.5 is like 109 on ebay. rebuild might cost 60-70 and cheap engines arent as powerful then the 2.5 soo depends pon whats engine you have and what engine your switching too
and sry for the mistake it was sapose to be long not low
