RC Drifting Discuss all aspects of rc drifting here!
RC NOOB here...
Old 12-30-2005 | 01:26 PM
Default RC NOOB here...
Hi guys I'm looking into getting an electric R/C. Are there ones that drift? Can I modify an ordinary one so that it can drift? Thanks.
Old 12-30-2005 | 03:00 PM
Default RE: RC NOOB here...
I dont know of any cars that can drift, if they do its probably a certain type of track which i have not seen any drif tracks.
Old 12-30-2005 | 06:22 PM
RC-Drift UK's Avatar
There's nowt like good advice [:@]
ANY 4wd car can be set up to drift, it's all in the tyres
Any electric 4wd tourer is a great candidate from the humble TT01 to the exotic xray's & corally's, just replace the normal grip tyres with ABS, PE, insulation tape or hard drift rubber
Hope that's a bit better info for ya (both)
Old 12-31-2005 | 01:47 PM
Rc EnthuSiasTs's Avatar
Yokomo makes some cool drifting cars. I tried once to find out what was so special about them. I think just alittle wider chassis. But i agree it is all in the tires.
Old 12-31-2005 | 01:54 PM
tamiya drift kit. the tt-01 or the ta-03
yokomo drift rtd
tc 4 rtr with some abs
abs and pvc are hard plastic pipe you need to drift. you'll hear about them alot in here.
they are availible at you local hardware store for cheap or local pluber might have some.
Old 01-01-2006 | 01:25 AM
ORIGINAL: gogita502
yokomo drift rtd
I'm sorry but what are you reffering to when you say ABS or PVC???
Old 01-01-2006 | 01:30 AM
The pipe, you know, that water normaly goes in. PVC pipe. home depot has it.
Old 01-01-2006 | 07:40 PM
The TT-01 is a great car to start off with i personally have one and it works great. http://www2.towerhobbies.com/cgi-bin...&I=LXHWN0&P=ML that is the kit that i got but notice that there are a few thing that u need to buy in order to get it running also this is a kit so you need to build it. if your not happy with you building skills then go for the RTR version where it already comes assembled http://www2.towerhobbies.com/cgi-bin...?&I=LXJSV9&P=7 but also notice theres still things needed to be bough with the RTR version like batteries for the radio and a battery and charger for the car, if you have a higher budget then try aiming towards the yokomo kit/rtr this is one kit http://www2.towerhobbies.com/cgi-bin...?&I=LXJDB9&P=7 and this is one RTR http://www2.towerhobbies.com/cgi-bin...?&I=LXKDE8&P=7. along with all that you want to buy PVC pipe with a 2inch inside diameter which can be found at a local hardware store...if u dont have any idea wat pvc pipe is im sure if u go to ur local hardware store and ask around ull find it.
Old 01-01-2006 | 10:26 PM
THANKS! you guys are very kind!
