Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Drifting
 best battery to use for drifting >
RC Drifting Discuss all aspects of rc drifting here!
Old 07-07-2006 | 02:09 PM
Default best battery to use for drifting
what kind and type of battery should last long enough for fun filled drifting? im currently using a venom 3300 nimh battery and a racers edge sp3000. i want to get another battery so i can drift for a long time. any suggestions?
Old 07-07-2006 | 02:33 PM
Banned
Default RE: best battery to use for drifting
Just charge your batteries at like 2.0 amps and you'll get great runtimes. Or if you want, and have the money, you can get the Yokomo or IB 4200maH packs.
Old 07-07-2006 | 02:52 PM
damn they make 4200!? how long does it take for the batterys to charge at 2 amps for the 3000 ones
Old 07-07-2006 | 03:00 PM
Banned
Maybe half an hour or so.
Old 07-07-2006 | 03:18 PM
RC-Drift UK's Avatar
3K NiMh's @ 2A will take between 1 to 1.5 hours depending on how discharged they are
You can even get 4300's now
Kev
Old 07-07-2006 | 03:25 PM
how long will play time be?
Old 07-07-2006 | 03:28 PM
Banned
About 1 minute of runtime per 100maH of battery capacity. Damn, how many times hsa this been asked?
Old 07-07-2006 | 04:00 PM
what about charging at one amp
Old 07-07-2006 | 04:12 PM
Banned
1 amp charging will give you a lack of punch.
Old 07-07-2006 | 04:27 PM
You won't properly charge the pack at anything below 2A, just get 2 or 3 packs of 3700's which you can get for about 25 bucks a pack and charge them at 4A
Punch is the least of your problems if you're drifting on plastic, punch is for grip racers
Anything above 4A will see a slight increase in punch and a slight decrease in runtime but will reduce your cells lifetime - NiMh's DON'T LIKE HEAT
Kev
Old 07-07-2006 | 04:37 PM
Banned
I charge my cells @ 5 amps when I race spec class. That way, the cells will get used to the demands of a hotter motor. But 2-4 amps will do you just fine.
I find that punch is somewhat important when wanting to use the throttle to change angle and attitude mid-drift. Sure, if you're full throttle most of the time, it won't really matter, but I'm just picky like that.
Old 07-07-2006 | 04:50 PM
i use 3300 nimh and they last about one hour on full drift ... not bad at all ... i charge them at 4amps ...
