What is .....
1.The best way to cut your body posts?
2.PVC,ABS, Yokomo Drift Rings Tamiya Type D tires which is best or ae they generally the same?
3.What type of Spur gear and Pinion should I use with the Tmaiya RS-540 Sport tuned motor in my TT-01?
4.Does the wiper,muffler and mirror set from yokomo fit well on a Tamiya TT-01 Body?
5.are alluminum wheels worth it (besides the look)
1. I use a stanley knife
2. ABs is better than PVC, yoko single rings are best but expensive, Tamiya's are too grippy, ABS is best value for sliding with a bit of grip.
3. Something like a 58/22 is good for Sport tuned.
4. Yes, you need to drill holes for a licence plate to mount the muffler, wipers are ok, mirrors depend on the shape of shell you put them on, will prob be ok.
5. I would say no, its far too much cash to clip a kerb and wreck, jus get some Speedway 37r's or something and keep the change, a lot of it!
MI
here's a TT-01 with the yokomo wiper, muffler kit on. ABS is dirt cheap, works great,...agreed with gearing, 58/21-22,..aluminum are great for shelf queens,...but not practicle in my opinon for running.
Banned
Dont Cut them, If You cut them then you will have Very limited Shell selection
ABS/Black Polypipe Offer best Slip for Grip, If You really want to have Authentic looks and some High Speed fun on a Polished Concrete Floor then go the rift Tyres
I Use The Stock 19/61 Ratio in my TT-01 and it handles my 10x2T Motor with Ease and Very little Heat Build up and Is Great for Drifting.
Yes. they will fit most Shells
I Find Plastic Wheels do the job fine, If You mean Aluminium as in Chrome Plated Rims? then I have discovered that over time the Chrome Chips off leaving an Ugly looking Rim..
