TL-01 Help
Hi guys, i havent used my 4wd shaft driven electric tamiya TL-01 1/10th scale for some time, and i wanted to start getting into drifting just for a mess around for awhile untill i get a better car, do i have to do any modifications to the car to make it drift or do i just have to put ABS/PV w.e tyres on it?
here is a full spec on the car just in case
http://www.abcmodelsport.net/p348236...-GT3-TL01.html
Help is much apreciated
Steven.
Steven.
Get a cheap bearing set for it as well; just as a safeguard. Otherwise nothing more is needed. If you find it hard to get into a slide, remove the rear diff and pack it out with some blue tack. Start with a little; then build it up, you don't wanna go straight in and lock it up completely like a lot of people will tell you to do.
Chris.
Chris.
ok thanks, so its only the wheels/tyers i need, but just a spair pair of bearings just incase mine pack up? its vertualy new, i havent even got the shall done ive had it bout 2 years, but the guy at the shop sold me the wrong paint so its kidna messed up, anyway of getting it off without destroying the plastic?
ON, CANADA
ORIGINAL: omightyone
yeah i coudl do with some help i dont know what to do with them apart from drive them and stick it together with the manual :P
there the wheels i was talking about; http://www.tamiyaclub.com/picturefra...07221724_4.jpg
And thanks for your help guys.
im verry grateful.
im verry grateful.
