POST A PIC Of YOUR DRIFT CHASSIS THREAD
#106
PA
Tamiya TA03F Runner
Tamiya TA05 Runner
Tamiya TA03R-S Shelf Queen
Tamiya FF01 Soon to be runner
Futaba 3PK Black
First two are for Drift.
Tamiya TA05 Runner
Futaba 3PK Black
#110
FL
The micro rs4 has a penguin chassis el, a graupner 300 6v motor, stock esc and hpi rims and drifting tires. It has rear ball diff and front solid diff. Alloy knuckles and also have a solid rear diff which I have not tried yet. I'm currently setting up a M18 for drifting so pics coming soon
Here is a pic of Micro rs4 with the body
#112
PA
Here is my TC3 drifter.
200mm conversion
27 turn Trinity Monster Horse Power Motor
Custom made ABS drift tires mounted on Black Rims
Blue Heat Sink installed on motor
Carbon Fiber exhaust Pipe (for realistic looks)
Spektrum 3000 receiver
3600 Nimh battery
Novak esc
200mm conversion
3600 Nimh battery
Novak esc
#114
PA
ORIGINAL: fl0PPsy
Hey just out of curiousity, whats involved in the 200mm conversion ?
Basically I picked up the TC3 Rally Conversion and used the new CVD's and arms. Everything else i left in the box. It makes the TC3 much wider. With standard offset rims the tc3 looks hella nice with the 200mm bodies now. Next I will be adding some 9mm offset rims to give it the tuner look. I will post some pics of the TC3 with the conversion and a 200mm body soon.
#115
FL
Here's some picts of my nrs42 drifter. I would tell you all what all I've done to it but that would take to long (that or I'm to lazy). Tell you what the only thing I haven't replaced is the bulkheads. Can't seem to find any aluminum replacements for them. Anyway I'm happy with it.
#116
ORIGINAL: pesty351
finally a fellow NRS4-2 drifter, do you drift with those tires?
ive been trying to get my car to drift with rubber tires but its a bit difficult. takes practice im sure but what are your settings?
i locked my rear diff and left my front open.
where did you buy your aluminum steering crank? i broke mine
#117
PA
ORIGINAL: h8eternal
nice
ORIGINAL: pesty351
#119
FL
Those aren't rubber tires there the hpi drift tires. Just wore down a bit. As far as my setup goes I don't change much for drifting. Just tighten down the preload and throw a stiffer sway bar in the back. My car always had a lose rear end in the corners anyway. As far as the bell crank Ebay is your best friend
#121
ME
My new 350Z chassis and body *not trimed tottally yet* and i was supposed to get my battery on monday but yet no batterys at my house for my car....[&o]
#123
ORIGINAL: FallenSnow
These two are my TT01 and TG10, I havnt got any upgrade to them yet. Can you tell me if my drift tires are good?
#124
heres my setup. i run yokomo SD SSG and yokomo SD with a black carbon kit, novak 5800 with upgrade rotor, hitec 5965 servo, and yokomo single ring.
let me know what you guys think.
cheers!
cheers!
#125
CA
HEY GUYS I HOPE YOU GUYS DON'T MIND IF I ASK A QUICK ? IM GONNA BE BUYING A CAR SOON FOR DRIFTING AND IM LOOKING AT TT01. BUT THE TT01 THAT IM LOOKING AT DON'T SEEM TO HAVE ADJUSTABLE CHAMBER IS THAT SOMETHING THAT I SHOULD WORRY ABOU T RIGHT KNOW. THANKS FOR THE HELP ONCE AGAIN SORRY INTERRUPT THIS POST TOPIC.
