RC Drifting Discuss all aspects of rc drifting here!
cheapest drifter
Old 05-07-2007 | 08:29 PM
s7jstep1's Avatar
Default cheapest drifter
what is the cheapest rc that can be used for drifting? i have a mamba max 5700 if needed
is this any good?
[link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGFY6&P=0[/link]
can these be driven on a smooth dirt track?
Old 05-07-2007 | 08:57 PM
maxxdout's Avatar
Default RE: cheapest drifter
thats cheap. i might think about that!
Old 05-08-2007 | 03:21 PM
GTB
Man that's really cheap
Old 05-08-2007 | 04:06 PM
That would be perfect for drifting. It's more than enough for drifting, and you can still have a ton of run bashing and racing it.
With the right tires it can definitely be run on smooth dirt. Tamiya makes rally wheels/tires that should bolt right up.
Old 05-08-2007 | 05:56 PM
That will amke a decent drifter. The spur gear and motor mount is the weak link in the TT-01, so do be cautious not to put a motor in that has super strong brakes or too much torq. The gears will strip rather easily.
Old 05-08-2007 | 06:31 PM
s7jstep1's Avatar
so the mamba is out of the question until i upgrade?
Old 05-08-2007 | 06:51 PM
lol, that should work, but don't go huntin for a 3.5 or 7700 with a TT01!
Old 05-08-2007 | 07:09 PM
webdr's Avatar
Ive heard a few times that a tt01 and a brushless= stripped gears.
Old 05-08-2007 | 09:43 PM
i'm still running my tt01 with the mamba max 5700. no stripped gears yet. it's a great drifter with both abs and drift rubbers. with regular tires the car is fast as hell! i have the subaru wrx sti version with alu shaft, ball bearings, adjustable upper arms, and adjustable tie rods. it's touchy at full speed but still it fun! i think you'll be happy with the 5700 mamba and the nsx.
Old 05-09-2007 | 10:20 PM
s7jstep1's Avatar
actually i have changed my mind on the nsx, i like the subaru because of the esc over the msc
Old 05-10-2007 | 05:15 PM
Why do you want a mamba?
Old 05-10-2007 | 06:25 PM
tuning probably. plug it into computer, set it up and go. ive heard nothing but good things about mamba motors. im torn between a mamba and a novak
Old 05-10-2007 | 08:42 PM
s7jstep1's Avatar
ORIGINAL: Kevin.
why not
Old 05-11-2007 | 11:25 PM
lol cheap drifting with a brushless
Old 05-12-2007 | 09:35 AM
Neon_guy's Avatar
You'll be fine with that. Whether or not it's a good drifter or not depends on the driver. So, if you suck, it will too. If you're the BEEZ KNEEZ, then it shall be that as well. The TT01 isn't the least expensive. Not neccesarily the "cheapest". Just take care of it and you'll be good.
