My drifting chassis
FL
My drifting chassis
Hey guys I just got this chassis and i am going to set it up for drifting. I also have a tt01 and a Nascada so lets see how this one feels. Is a TC3 with a GM Racing V3R Digital ESC, Trinity Green Machine 27 turn motor and a hitec HS-525BB high speed steering servo. I am going go lock the rear diff and get new rims and body. I am thinking of a RX7 body, Does this chassis has Potential? What do you guys think? Any advice is welcome.
TN
RE: My drifting chassis
Hey pretty nice setup. All I did to mine was tighten the rear differential. I use Yokomo drift tires, but see if you can find ABS pipping it last alot longer.
NY
to tighten your rear diff, you can use lock-tight. That's the most popular way I've heard of it being done. I just used a screw and a pipe cleaner and it did the trick. Your set-up is fine as is tho.
