RS4 EVO + DRIFT conversion any tips ?
QC, CANADA
Hi,
I got an rs4 evo + and i wanted to convert it into drift and i wanted to know with wich upgrade or setup people had experienced the best results.
I presently got drift tire as the one on the nitro drift 3 and the sway bar kit ( wich color should i use for drifting )
Do i need to convert to i speed tranny or just ajust the shifting range ?
Is stiff coil sping needed ?
My friend a the nitro 3 drift and it drifting so well i would like to convert my rs4 into drifting and obtain the same drifting experience !
any ideas ?!?!
any ideas ?!?!
What ever the engine is, it will need as much air as you can give it to keep it cool. Cut the side windows out since your going sideways more then straight forward, the one in the windshield isnt gonna do much. Run it rich to help with temperatures as well. Slap on your tires and go have fun! Suspention settings are a personal preference that you will develope as you get experienced.
Cheers.
Cheers.
QC, CANADA
the engine is a t3.0 but i'm planning to swap in my o.s. 18cvrx in it maybe this fall ! and i do matter about cutting big holes in my body !! i think it is better to keep it not to hot !
