2wd Drift Tips?
I'm part way in the making of my asphalt stampede project and I was thinking of a slight detour. I've lowered the stampede and the shocks have 45 wt oil and some really stiff springs. I was pondering about creating some pvc or abs drift tires.
Can you guys give me some tips on 2wd drifting? Frankly, it's harder than 4wd :/
CO
Honestly...stick with 4wd or you will be frustrated. It's basically impossible to maintain controll of a 2wd drifter around a track. Sure you can slide a 2wd RC, but you'll have a super tough time getting it around an acutal drifting track. My advise is stick with 4wd and cut (or buy) some ABS that fit's your rims.
I know it's not what you wanted to do, so sorry if I didn't help.
probably... lots of "Depends on what you expect"
Lots of people throw brushless in a tt01 and fly around
Good thing is, parts are cheap
If you chew up some spurs just PM me
I'll send you some extras for the cost of shipping. Only as long as you become MASTeR OtaKu TaCo DrifteR!!! jk
anyways, welcome to drift
with brushless make sure to upgrade to ball bearings, aluminum shaft and aluminum motor mount. i would lean towards a sensored system over a sensorless system in a tt01 because the sensorless systems arent as smooth so they jar the gears a little more. Also anything faster than a 8.5t (5000kv) and the car will sound disgustingly (or awesomely) loud but the car will hold up to it fine. i ran a novak 7.5T in mine for a long time and then a 6.5 slyder for a while.
Man, I really wish I hadda video cam...
You should see your old bandit drift with paddles, ski's and an inch of snow, its wicked!
Throttle control is your only hope to drift 2wd, and its very difficult... I would suggest (lightly so it won't cave in the tire) wrapping a set of back tires with electrical tape, with the end of the tape going the right way, and a dab of tire glue on the end so it won't unravel on you, and give her a whirl. A sensored bl system is a must if you want total control, especially at low speeds. I get by with a mm/3500. Try (if you can) a brushed system first and see if it helps your control the pede.
I drifted a tandem axle, 5 ton propane bulk truck last week. Talk about trippy, lol. I will drift anything I can get my hands on, 94' fwd cavi, 88' thunderbird, 72' yamaha snowjet, old tractors, ANYTHING!
You could say I'm obsessed with drifting...
Cheers.
You could say I'm obsessed with drifting...Cheers.
I don't think you need that much power for drifting
Also, seeing as you will be using drift tyres there wont be any grip so you wont break any drivetrain
