RC Drifting Discuss all aspects of rc drifting here!
problem with my drifter
Old 05-23-2009 | 02:24 AM
Default problem with my drifter
i have a tt-01d and when the battery gose flat it goes stops goes stops .... well know when i had just charged it i start to go and then it goes like its flat the charger says it giving out the amount of power i need .......... but i see there it marks and sraches on the copper in the motor so i dont now what it is.
Old 05-23-2009 | 09:38 PM
Default RE: problem with my drifter
Running a battery until it is almost totally dead is a big no-no. Even for lipos. When you notice it starting to lose considerable power and punch is when you should stop using it, let it cool down, discharge on a tray and then recharge. I don't use lipos yet so I don't know if after each use you should balance it and then recharge.
<br type="_moz" />
Old 05-24-2009 | 02:39 AM
that does not help me my car is broken when it is just recharged it goes like it is flat
Old 05-24-2009 | 03:29 AM
you may just have ruined yur battery dude... the same thing happens to mine when they go flat with the sop start stop start thing but iv just killed a battery and its the same problem... iv tested the current going through it and its working fine my car just wont recognise it... so dunno what to tell ya... but ima throw my battery out as i did the same thing now its screwed... owel i have like 6 more haha
Old 05-24-2009 | 06:31 AM
Sounds like the battery is already ruined. It only takes one time to over discharge a battery and ruin it. I've done it before. It stinks making mistakes in this hobby 'cause it gets expensive.
Old 05-28-2009 | 02:30 AM
god yous a dumb this forum is no help. it is the <u>ecu</u> god yous. all went on about the battary
Old 05-28-2009 | 11:29 PM
ORIGINAL: jetto
You butcher the english language like that then have the gall to call someone else dumb? By the way, I think you mean ESC... I have no idea what an ecu is...
I suggest you provide a lot more information such as: what esc, what motor, what battery, what voltage did your battery read when fully charged, how much mah did you put back in the battery... etc.
Old 05-29-2009 | 03:34 AM
agreed... learn english... econdly you gave almost no information except how you charged the battery etc... as though you wer sure the battery was the problem... i assumed you would have checked the ESC already! d@&amp;khead
Old 05-29-2009 | 07:14 AM
ORIGINAL: AusDrifter18
You tell him A!!
