Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Drifting
 Question about wheels and setup >
RC Drifting Discuss all aspects of rc drifting here!
Old 04-30-2010 | 07:19 PM
Default Question about wheels and setup
<span id="result_box" class="medium_text"><font size="3"><span title="" closure_uid_wew51v="118" kc="Что лучше: обычные колеса на 26 мм или из LP серии HPI (29mm, 32mm, 35mm)." lc="Which is better: the usual wheel for 26 mm or LP series HPI (29mm, 32mm, 35mm)." style="background-color: #fff">Hi!
1) Which is better: the usual wheel for 26 mm or LP series HPI (29mm, 32mm, 35mm)?
</span><span title="" closure_uid_wew51v="187" kc="У меня HPI Sprint 2 Drift с заводским мотором (Firebolt 15T)." lc="My HPI Sprint 2 Drift with factory engine (Firebolt 15T)." style="background-color: #fff">2) What setup for drift?
3) Which shock oil do you use in the front/rear?
I ownHPI Sprint 2 Drift withstock engine (Firebolt 15T).
</span></font></span>
Old 05-01-2010 | 08:57 AM
leadfootdriver's Avatar
Default RE: Question about wheels and setup
Your shock oil is fine don't spend money on what you don't need and your chassis should already be set up for drifting that's how it comes from the factory and I like the 26mm tires personally I had a pair of the LP's Ran through them in about a month and a half where the regular 26mm tires last double the time 3 months so that ain't bad
Old 05-01-2010 | 10:55 AM
droppedgmc's Avatar
My Feedback: (18)
1) Which is better: the usual wheel for 26 mm or LP series HPI (29mm, 32mm, 35mm)? I really like the LP's. very smooth and look grreat. So far they have lasted a while also. If you went with the 26mm, you could use ABS if you wanted
2) What setup for drift? start with 0° toe in front, - 1° camber all around. Also get the ride height up on the sprint. I've noticed they ride low from the factory and eventually start scraping the ground
3) Which shock oil do you use in the front/rear? Use 30-35wt oil all around or 400-500cps
