Where to get Paint
AB, CANADA
<span style="font-size: larger">I need help buying paint for my body http://www.hpiracing.com/products/en/17530/because going to buy this for my exceed drift star</span>
AB, CANADA
Spaz Stix Prep is all Isopropyl Alcohol, it says so on the label so save the money and get a big bottle at the pharmacy. rippnlip is right, your body needs to be squeeky clean, that and minimal paint thickness is the key to a good paint job. If you lay on thick layers it will chip. Lay enough color just to cover and a light backer coat. For better paint adhesion some guys etch the body with a scotch bright pad. If you do this you need to wash the body really good before painting.
THANKS, DID'NT EVEN THINK OF ISO. OR ETCHING THE BOD, MAYBE I SHOULD KEEP AWAY FROM SOLID OBJECTS LIKE CURNS AND MY DADS CAR, TO KEEP FROM CHIPPING MY PAINT!!!!! HA HA.</p>
