RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   xmods drifting (https://www.rcuniverse.com/forum/rc-drifting-304/4401483-xmods-drifting.html)
FireStriker 04-11-2007 11:55 PM
RE: xmods drifting
ORIGINAL: mOnO n.s.G^
ORIGINAL: FireStriker
But in my source there are no Xmod parts![:'(]
[sm=50_50.gif] im confused:)
In canada, we don't have Radio shack they got a new store called "the Source".
mOnO n.s.G^ 04-12-2007 12:47 PM
RE: xmods drifting
oO :) lol
FireStriker 04-13-2007 01:13 AM
RE: xmods drifting
LOL!
2WDrifter 04-17-2007 05:07 PM
RE: xmods drifting
i have my tt01, but usually i only get time inside the house, so xmods are good for fun. they are good for practice because they are harder to drift, so when you get around to drifting your 1/10, it's easy
mugenx 04-18-2007 10:47 PM
RE: xmods drifting
Yea Radio Shack was renamed The Source CC in canada.
BTW
I got a first gen skyline xmod yesterday cuz it was like half price at the source. It was for 24.99 CAD, and i found it very slow so i ordered an Atomic Standard Motor, aluminum wheel nuts (the plastic ones split to easily), and some ball bearings, all from atomicmods. Im planning to get a heatsink and white pinion gear set soon. Also, the source has no upgrades what so ever except for wheels, rims, and bodys. I cant find an AWD mod anywhere.
Heres some pics (i decided to convert the skyline to a nice rsx with foam tires :D):
http://img484.imageshack.us/img484/1500/dsc00259co8.jpg
http://img484.imageshack.us/img484/6250/dsc00260ex8.jpg
http://img245.imageshack.us/img245/1851/dsc00261bg9.jpg
mOnO n.s.G^ 04-18-2007 11:15 PM
RE: xmods drifting
**** is crack
FireStriker 04-19-2007 03:14 AM
RE: xmods drifting
Looks Crazy,
pretty good price, Eh?:D
mugenx 04-19-2007 07:33 PM
RE: xmods drifting
wow, i grabbed some duracell 1000mAh rechargeables today, and they make my xmod go like 100 times faster than the alkaline batts!!
FireStriker 04-23-2007 03:31 AM
RE: xmods drifting
Yay they have a great affect,
also the runtimes are greatly increased,
[8D]
FireStriker 04-25-2007 03:36 AM
RE: xmods drifting
Hey huys guess what??,
Today i went and got a Bearing kit and Stage 2 motor!,
The only problem is that they didn't have 4WD so im tryiung to drift with the stock 2WD with the diff locked,
Any Tip$!
mOnO n.s.G^ 04-25-2007 01:17 PM
RE: xmods drifting
yea 4WD lol idk howd u lock up the diff:D
hotbodiesboi123 04-25-2007 05:22 PM
RE: xmods drifting
lock the diff with hot glue gun or super glue. i got all the upgrade except lowering kit mitsubishi evo 8. im a pro at drifting xmods i can drift perfect circles like tokyo drift .
FireStriker 04-27-2007 12:26 AM
RE: xmods drifting
Cool, I already locked the diff!,
Im getting 4wd today!
2WDrifter 04-29-2007 09:36 PM
RE: xmods drifting
you just got 4wd? i got all my upgrades before buying the rc car:) it saved me some hassle i rewound my motor so it would go faster than the ratshack's stage 2 motor, and it worked
mOnO n.s.G^ 04-29-2007 11:31 PM
RE: xmods drifting
ORIGINAL: 2WDrifter
how u do that?
FireStriker 04-30-2007 10:45 AM
RE: xmods drifting
Cool, but remember im not as rich as you guys!:).....LOL!,
I lover rewinding motors.................Unless i screw up a new motor.LOL!:)
mOnO n.s.G^ 04-30-2007 01:21 PM
RE: xmods drifting
how do you rewind the motor and firestriker what method did you use to lock up the diff
FireStriker 05-01-2007 01:22 AM
RE: xmods drifting
To lock it up I used the ol' Super Glue Method,
To rewind a motor, you nedd special wire and a motor to start with!,
Ill tryy to find a tut for you!
mOnO n.s.G^ 05-01-2007 02:07 PM
RE: xmods drifting
when you rewind a motor what difference does it make?
mugenx 05-01-2007 06:53 PM
RE: xmods drifting
whered you get the 4wd?
FireStriker 05-02-2007 03:35 AM
RE: xmods drifting
From the source, They had a few peices mostley for trucks, but i found the 4wd in the pile!
If you already have a motor that has less them 50 hours on it.........None!
2WDrifter 05-02-2007 04:57 PM
RE: xmods drifting
1 Attachment(s)
you have to take the motor apart. and FireStriker, it doesn't matter how many hours is on it.
all that matters is the # of winds (please keep it above 35t or you'll blow your stock FET's) and the thickness of the wire.
here's a tut i found on xmodsource.com (Thanks RedSXmodder!):
I suggest that you do this to a stage 1-2 motor for practice. Or an old motor that you have no use for for practice.
Basically, when you rewind a motor, you make less or more windings of a thicker grade of wire. when you do this it creates higher RPM'S, or more torque. MAKE SURE TO COUNT YOUR WINDS
[img][/img]
Here we go
1. So first, you have to dissassemble the motor. You usually start with the 2 metal tabs on both sides of the motor. Oh yeah, if the motor you are performing this on has a pinion, remove the pinion so you can take the can off.
2.After you have accsessed the guts(inside of the motor), You will come across the armature which is the rotating arm inside the motor.
It has 3 arms in which wire is wrapped. I believe these are called poles
3.Each wire is soldered to a tab an the commutator. The commutator is at the end of the armature. There are 3 small tabs in which a wire is soldered or crimped onto, which is then wrapped around the poles or arms on the armature.
4.Desolder the wires on the commutator and unwrap the windings.
5.After that take your new wire of desired thickness(prefferably thicker than the stock wire) and solder (or crimp) the begining onto one of the comutator tabs. Be sure to scratch away some of the enamel coating.
6. Begin wrapping the wire in a pattern around the poles. Make sure that you have the same # of windings on each of the poles.
7.When your done with the first pole, move onto the second pole. Repeat for the third pole. Again, make sure to cound your winds.
8.After you get the winding done solder everything back into place. If you have been thinking about any other engine modification, now is the time to start working on that. Such as the neodymium(spelling?) magnets mod, or carbon brushes.
9.Lastly, put the armature back into the can, make sure the brushes fit comfortably over the commutator, and carefully insert the endbell.
More winds=more torque, and less RPM
Less winds= more RPM, and less torque
here are the images that go with it
mugenx 05-02-2007 11:20 PM
RE: xmods drifting
@firestarter Which source? Yorkdale?
FireStriker 05-03-2007 06:17 AM
RE: xmods drifting
Yah the 1 at yorkdale or the 1 at oakville, close to the GREAT CANADIAN SUPERSTORE!
FireStriker 05-03-2007 06:18 AM
RE: xmods drifting
ORIGINAL: 2WDrifter
Iw as just about to post that tut!,
Sorry for the confusion!:(:(
