RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Traxxas Slash 2wd- Rear stub axle carrier
Old 07-02-2013, 07:30 PM
ghostcrab911
Default Traxxas Slash 2wd- Rear stub axle carrier
Rc universe community,
I broke a rear stub axle carrier today on my 2wd traxxas slash while out bashing. What is the best replacement for it at this point in time? Do I go with the same stock part or upgrade? Once I do get the new part, do a need a new bushing? If no, how do I replace the existing one?
-Patrick
Old 07-03-2013, 04:01 AM
collector1231
Moderator
collector1231's Avatar
Default RE: Traxxas Slash 2wd- Rear stub axle carrier
The stock ones are very tough. Just stay stock.
Old 07-03-2013, 04:38 AM
phmaximus
phmaximus's Avatar
Hey, that's the first part I broke too...
I would recommend replacing it with a RPM one. They have a lifetime warranty against breakage.
For US $8 u can't go wrong.
Check em out here...
http://www.rpmrcproducts.com/products/traxxas/slash.htm
Ps, once u have taken off the wheel hex, lock pin, and stub axle, the bearings just puts out
Old 07-03-2013, 06:47 AM
ghostcrab911
RC Universe,
So far I have...
1 Stock
1 RPM
Which one is it? I need some more opinions.
-ghostcrab911
Old 07-03-2013, 07:23 AM
EXT2Rob
EXT2Rob's Avatar
It's pretty generally known around here, that RPM makes better replacement parts than the OEM. And from what I've read, pretty much every Slash owner replaces broken parts with RPM parts, because they ARE tougher than the stock.
Old 07-03-2013, 07:49 AM
SyCo_VeNoM
SyCo_VeNoM's Avatar
ORIGINAL: EXT2Rob
It's pretty generally known around here, that RPM makes better replacement parts than the OEM. And from what I've read, pretty much every Traxxas owner replaces broken parts with RPM parts, because they ARE tougher than the stock.
Fixed dat
Only RPM part I heard of that sucks is the wheel hubs on the merv due to them being too soft, and the ball ends pulling through.
Old 07-03-2013, 08:08 AM
ghostcrab911
I'll go ahead and order a pair of RPM ones then. I know phmaximus already said I could transfer the bearings from the existing rear stub axle carriers to the new ones but the traxxas slash comes stock with bushings. Is that correct? If so, do I need to replace those?
-ghostcrab911
Old 07-03-2013, 11:15 AM
EXT2Rob
EXT2Rob's Avatar
Oh HELL yeah!  BUSHINGS?  That is so 1985!  Gotta get BEARINGS, mate.  If your slash has bushings, replace them everywhere.  Check the tranny and if it has bushings, replace them too.
Syco - Are you saying he SHOULD NOT get the RPM rear hub carriers, because they are the only RPM part not tougher than stock?  That would be really weird on RPM's part........
Old 07-03-2013, 05:05 PM
phmaximus
phmaximus's Avatar
Are u sure its bushings???? I've never seen a slash with bushes only bearings.... Are u sure?
Old 07-03-2013, 05:07 PM
phmaximus
phmaximus's Avatar
Some other options too.....
If u are more into racing and fine tuning look into the alloy STRC ones or the Proline ones
Old 07-03-2013, 05:46 PM
SyCo_VeNoM
SyCo_VeNoM's Avatar
ORIGINAL: EXT2Rob
No meant the only part they make for all the traxxas models that is weaker then stock is the wheel hubs on the 1/16th Mini Revo(which doesn't mean anything in this case)
Outside that if it breaks RPM it on all Traxxas models
Old 07-04-2013, 09:17 AM
ghostcrab911
phmaximus,
You were right. The slash does have bearings, not bushings.
Thanks for the correction,
-ghostcrab911
Old 07-04-2013, 09:19 AM
ghostcrab911
I think the RPM ones would be the better bet since I'm not too into racing...yet.
Thanks for the alternate option though.
