Metal Spur destroyed my Pinion Gear - repost from RC engines
I have an Axial Yeti and I replaced the plastic spur with a metal one from gpm racing. It was noisy so I adjusted thr motor position a few times trying to make it less noisy.
After about an hour the spur had worn the pinion gear down to a nub.
Is there something I can do to prevent this from happening again? Or do I need to switch back to a plastic spur ?
Sometimes a manufacturer will "goof" on the composite for certain parts, and have a so called "bad batch". Sometimes a manufacturer won't care and only intends for their product to handle lite duty, and then you have to hope for aftermarket parts to show up and fill the void. That being said, I found nothing wrong with the stock Axial Yeti spur gear. I was running a 1/8 scale motor, and 3S LiPo setup...spur gear was handling it just fine. Me personally, I would run a plastic spur gear whenever I can. Now the rear axle's output bearing is another story .
What brand of pinion gear were you using?
The spur I have on there is this one:
https://www.gpmracing-parts.com/axia...-90068813.html
I just ordered this pinion gear:
https://www.amazon.ca/dp/B001SEVSN0/..._nbzJzbMYZ8V1M
Both look like 32p and hardened steel. I should be in good shape now. Thanks for thr help.
If the Traxxas one doesn't hold up try these:
Robinson Racing Products - Products and Pricing 5MM BORE MOTOR PINIONS
https://www.horizonhobby.com/extra-h...-5mm-p-rrp8614
The plastic spur gears are supposed to be a sacrificial part. When something goes wrong in the drive line, etc...the plastic spur will let go before anything else gets damaged and for a few dollars it's easily replaceable.
A metal spur will not break but rather allow the next weakest link to break.....usually something in the transmission.
High amperage, high speed/torque modified vehicles do better with a metal spur...as long as the rest of the drive line is beefed-up as well.
