Official Rustler Thread
#7353
ON, CANADA
RE: Official Rustler Thread
Well now i got a goal to get mine to get up to that kind of speed. In its current condition lucky to even jump off. Let alone do a flip.
#7354
VA
i want 2 know whats the biggest tire some of you have ran on a rustler i was thinking of a set emaxx tires on mine with the hub adapters extended with a pro line 1970 ford f-100 body with my mamba max pro esc 2950kv motor on a 4s lipo geared @ 16/90
#7359
ON, CANADA
I still running my originals though they are more like racing slicks on the rear now. Have a pair of Galdiators II on order though.
#7361
ON, CANADA
Well I won the esc for 25 plus shipping. not a bad price for one. its a NOVAK GTS Pro Sport ESC 12 Turn. Should work well with the new motor when I get them all together.
#7363
Well the off set seems to be the same. The tires are wider but maybe 1/4 inch. They are not bad I had them on the wheely king when before I got my crawler tires for it and they grip pretty good. I also have a set of the geolanders from hpi on my mt2 and they are good too I like those way more then the masher type tire. The hpi ones from the wheely king the tread is rounded it's not like the tread Rhys on the t maxx and e maxx
#7364
ON, CANADA
Well finally figured out what was making noise in my drive system. A good chunk of teeth on my dif. gear have been shaved/ bent over. Also wore out one of my bushings its now oval. So just add to my list of things that need to be replace.
Here is some pick of my local track. It is being listed as the largest in Canada. There will be nationals held here next year, and a few other big races.
The track still has some fine tuning to be done and finalized, but this should be the final lay out. There is also an oval, rock crawling, and plans for a boat pond set up.
The place is called Muskoka Madtrax. Their web site should be up soon. They do have a facebook page, and a few you tube vids.
Oh ya here is Huntsville ON.
#7365
Wow that's a nice track. If Huntsville wasn't so far away a few buddies and I would come up and check it out and meet up with you and race a bit.
#7366
ON, CANADA
Its not to far makes for a good weekend trip. When traffic is quiet its only a 2 to 2.5 hr trip. Lots of places to stay on any budget even a local Ontario park. You know you live in Canada when you measure distance by time.
#7367
ORIGINAL: Muskokarc
Also about you bearing, get the Ceramic ball bearing, they will last forever.
You can also use axle grease inside the transmission, and that will greatly extend the life of the gears.
#7368
AB, CANADA
LOL
ORIGINAL: Muskokarc
#7369
ORIGINAL: Muskokarc
#7370
ORIGINAL: Muskokarc
#7371
ON, CANADA
I do use grease on the internal gears. I guess the failure of one meant the demise of the other. I do plan to switch ball bearings. Another note is that mine dose not have the slipper clutch.
#7372
ORIGINAL: Muskokarc
The Slipper clutch in my opinion is useless, it ether slips to much, or not enough, so I just locked mine.
I am ruining mashers, so the axles were getting blown out anyway, so I just didn't bother with it.
Also, if you plan on ruining larger tires like mashers, get the MIP CVDs for it.
If you are keeping to regular sized tires then the CVDs don't do much.
#7374
ON, CANADA
Ya I am staying with same size tires going with Gladiator II 2.2 for the rear. Looking to get metal outer diff gear.
Here is a good question. Is it work changing as many parts as possible to aluminum/metal from the plastic or just high stressed areas?
At some point i plan to go brushless. I also planing to do the whole thing over about a years worth of time depending on funds.
Ya I need to get a guys weekend in some time myself. Always good to once and a while get away from the home on own.
#7375
ORIGINAL: Muskokarc
