Official Rustler Thread
#7901
RE: Official Rustler Thread
Hey what motor ya running, My Brother in law has some nice parts for sale soon, Twin cam head ported to the max, extractors for both types of heads, TDR supercharger and a few bits & peices
Ahhhh liquidrc are based in the US but thay still post here for only $1
#7902
Aljo
I buy my Auto-Air from the Aussie importer in Adelaide, company is http://www.airbrushmegastore.com/
My Clearcoat etc comes from Concept Paints in Melbourne. But you can use any good brand of 2k Clear.
I have a few k worth of painting equipment in my shed as I am doing some bike resto's etc from home. It's a hobby of mine I have done for years which is becoming a bit more serious now. I am self taught but have painted cars, bikes and even small aircraft (Cesnas etc) for awhile.
Note that Auto-Air is for spray guns or airbrushing. They don't have pressure packs etc. So unless you have some gear you will have to stick with what most guys use.
Hope this helps.
Hope this helps.
ORIGINAL: Aljo
That ESC/motor would hit over 100KM/h with a Max Amps LiPo 6000XL 60c 3-cell 11.1v battery, it would supply the max burst the ESC can provide 360AMP. That would be insane. My ESC max burst is 190AMP thus I use 5000MAH 40C but I will be buying a 3cell soon for the fun factor. Just a heads up if you go the higher voltage "For 7-9 cells NiMH or 3 cells Lipo: You must change the standard cooling fan because it cannot work with such a high voltage, so please choose a high voltage fan or supply the fan from the receiver (+6V)".
I have no experience painting a body and will be looking into tackling that soon yours looks like a pro panel beater went to town on it. Which store do you purchase your parts from here in Aus or if not in Aus where from?
ORIGINAL: Aussie Fly
Hi Aljo,
Yes it is a handful but I am new to electric so don't have anything to compare it to.
I bought it off ebay in the USA a few months back and had this combo in it but was running 8cell Nimh.
The gear box is standard but I am pretty sure it has the VXL gears etc.
It was running 89-16 gears with4.6" diameterTalon Stampede Wheels / Tiresso was good for just under 100kmh.
Cant give you any feedback on this tyre combo as yet, as there unused. I will let you know sometime this week what there like.
Hi Aljo,
#7903
I have no idea why I am running the 60a…..lol
It was on it when I bought it, it works well and it fly's!!
What more can u want :-)
ORIGINAL: phmaximus
hey guys...
Just wondering why a 60a ESC and not a 35A????????
With all by ezrun ESC i just soldered the fan wires onto the BEC, works a treat.
Aljo
Here is my fav places to get rc parts here in Australia
ebay.com.au
ebay.com
liquidrc.com (only $1 postage no matter what)
frontlinehobbies.com.au
hey guys...
Aljo
ebay.com.au
ebay.com
#7904
In my opinion the site I linked http://www.scriptasylum.com/rc_speed/top_speed.html takes more settings into account like Front/Rear Differential Gear Ratios, Transmission Gear Ratio, added radius of tire "ballooning" in inches, Current draw in amps & motor resistance in Ω to give a more accurate theoretical speed. But it does state that vehicle weight, battery quality, drivetrain drag - play a factor in the accuracy but after 45MP/H the accuracy is deminished by the aerodynamics and all those forementioned factors by a larger amount which in my opinion causes huge issues in the handling which translates into overall speed thus the body aerodynamics issue I mentioned in my 1st posts.
Do your brushless motors run hot after a 20min run? What temps do you see after a long run? My batteries last between 30 to 45min depending on terrain. I have heard mixed opinions on BL motor temps some say they are meant to run hot others say should be as hot as ESC heatsink and no more than 70celc.... Mine ESC never gets very warm and motor hurts to touch after 7 to 10sec. I have ordered motor cooling fans and hope that will help to lower the heat but as far as I am concerned seems fine I have even run it with a 17t pinion on 86t spur and still same heat.
#7905
Hey Fly cant wait to see some vid's
Aljo
Thats cool, Im old school, i like to work things out my self, but who would know how much there tyres balloons?, Motor draw? & motor resistance?. How would u even mesure these???? I know how to check draw & resistance on a brushed motor, but how do u do it on a brushless motor????
yeah yeah.. The rustler total gear ratio from motor to wheel is (spur/pinion)x2.72. Nothing els matters, as far as i know there are only 1 diff ratio & gear ratio for these cars.
Yes Im aware that these calculations will never be exact, but its bettter than nothing, mind u 45MP/H is fast for most r/c cars. & im not supprised that thay dont handle that well at those speeds, Hitting a 10mm bump would be like hitting a 100mm bump in a real car. Im shure there are more aerodynamic body out there but aint thay for mainly on road cars? I mean how fast do u want to go off road & is the off road surface suited to that speed? & ive found with one of mine that it seems to go noticeable slower off road.
Ive never had any problems with BL motors getting hot, dont know whats going on with yours, how hot is it?
Have u thought about getting a trx bandit? it might be more suited for speed, its lighter too
Aljo
#7906
Wow it was a busy night on the form. I ran the rustler on a indoor carpet track yesterday and it did well but I ripped the can of the motor mounting plate sonic going to jb weld it back together and away we go.
#7907
ON, CANADA
Wish there was a indoor track up here in Muskoka. Will have to settle with winterizing my Ruslter. Jackedman you know where to get the ski set for the rustler?? Will have to do some waterproofing with the old way with balloons.
#7908
OR
ORIGINAL: phmaximus
With lipo's the cell volage is alot higher than nimh, thay come in 1s 3.7v, 2s 7.4v 3s & 11.1v. there are higher voltage batterys too.
If u are planing to use a lipo with the XL-5 ESC u will need a lipo low voltage cut off, this will prevent the battery getting to flat (if a lipo gets to flat it can not be charged again)
One of the best cut off ive found & used are the novark lipo cut offs. it has a warning light that flashes then stays on, & when it getting flat it pullses the motor & when its down to the low voltage it cuts off the motor to prevent damage to the battery.
most brushless ESC have a cut off built in.
one good point about lipo's is thay still go as hard on a 1/2 charge just like when thay have a full charge, unlike nimh & nicad that just get slower & slower untill thay are flat.
ORIGINAL: B192734
So looking it up in the manual, it looks like the stock XL-5 speed control is listed for 4-8 cell (4.8-9.6v) for a NIMH battery. What would that translate into for LIPO? Do I just pay attention at that point to the voltage, or...? Also if I switch over to LIPO, is there anything else that I would need to get first, or can I just charge it up and plug it in and tear through the mud?
#7909
ON, CANADA
Here is a pdf of how it connects into your system.
http://www.teamnovak.com/download/in...smart_stop.pdf
#7910
ORIGINAL: phmaximus
ORIGINAL: phmaximus
Aljo
Aljo
Ya it gets pretty hot 7sec finger touch and it hurts I would say 80celc. I am gonna see how it goes after this major rebuild. I have run it about 26 times now 13 times per battery and no problems just a hot motor.
Nuh if I go buggy will go 1/8 4x4 buggy prob 2 stroke or maybe nitro. Come to think of it I am not a big fan of petrol really like the brushless setups so 1/8th 4x4 brushless.
#7911
ON, CANADA
Well i finally dusted my 1st gen xl-5 rustler off. and got some MAJOR UPGRADES. i had already gotten the steel diff set so no worries there. I got myself a futaba 2pl remote system. (for my Tmaxx3.3 and rustler) i have also gotten the castle creations sidewinder 4600 combo. 3s Lipo as well. let me say first of all THIS IS SUPER POWERFUL. wheelies no problem. so far stock gearing. seems to be getting warm to hot. need a temp gun next. does anyone else use this set up?
no idea top speed or anything just know its faster than my tmaxx by far!
#7912
I got my Rustler finally up and going again after about 2 weeks of motor issues with the Titan 12t. I got my new motor free from Traxxas after telling them how bad the first motor was, and I haven't had my Rusty in almost 2 weeks or so! They also sent me a smaller pinion gear for free. Ran 2 battery cycles through it, but both boring speed runs trying to break in the new motor. I'm getting a VXL Bandit at Xmas, so I"m super excited!
#7913
OR
ORIGINAL: Muskokarc
http://www.teamnovak.com/download/in...art_stop.pdf
Links not working. No worries. I can likely figure it out. Shouldn't be all that confusing. Question though. When you get everything hooked up, battery charged and you're tearing around. With the LIPO, when the battery gets to the low voltage point that it's supposed to cut out, does it actually just shut down, or do you get a warning letting you know that it's about to happen? Or does it just shutdown and you have to wander out to wherever it stopped and retrieve it?
#7914
ON, CANADA
Hmm odd, try just copying this one into your address bar and look for the right doc.
http://www.teamnovak.com/download/instructions/
The documentation says that it will light the light and the motor will pules and then stop.
#7915
OR
Good to know. I think I am probably going to go out and buys some goodies this week. Maybe try to have everything set up and ready to go by the weekend. There's a great little park not far from me that is usually totally empty. Nice dirt trails to run down, and a little creek, and some good mud. Everything you could ask for except jumps. I know there are so many different opinions out there, but are there any batteries and LVC's that are nice and cheap but good quality that people have found? I don't want to buy junk, but if there's something good out there I'd rather keep costs low if possible. That way more parts can be bought...
#7916
OR
Another quick question...
I currently am running 16/86 gearing. I have a bunch of other random gear sizes in the parts box at home, and was wondering if I switch over to LIPO's is there a better gearing setup to run for just bashing around, or would that still work just fine?
#7917
AZ
It's a known issue that the Novak 2s Smart Stop does NOT play well with the Traxxas XL-5 ESC. Blue cased ones don't work at all, and it's a gamble if it will work with the yellow cased model. It didn't on mine, caused all kinds of glitching, the ESC would blink on and off, and it acted like it was in training mode whenever the SS was plugged in.
#7919
OR
ORIGINAL: Jeckler
#7920
If you put a VXL system in an old rustler tranny thats plastic mostly, yall think it would last if you left the slipper a little loose and i only run 7 cells?
#7921
ORIGINAL: thehuntingterminator
#7923
ORIGINAL: Jackedman
#7924
Need some help finding a set of rims that are 2.8" suited for the Nitro Rustler front and rear that are not traxxas as they are very expensive here in Aus and I can't wait for shipping times during this busy time of year from the USA. What other brands and the modle of the rims should I look at? (Nitro Rustler)
Thanks in advance
Thanks in advance
#7925
NY
Hey guys,
Haven't been in the thread for a few days but there is some good news! I ordered the power supply I need to get my charger going and FINALLY run the rustler and it should be here in a few days. Super excited to get everything running good. Also, my used stampede from eBay finally came in! It was very dirty but overall everything seemed to be in good condition at first sight. The battery was a little more beat up then I thought, but hey, it was free. Also, the truck came with a lot of extra parts so I'm happy about that.
I didn't have any time to take pics because its going to be my christmas gift, so I only got to check it over for a short time..
I'll get some of the trucks up whenever
Brett
Brett
