OFFICAL PEDE THREAD
#2551
RE: OFFICAL PEDE THREAD
really, I want speed and all the more is better. My dads already suprized how well i keep up with his Revo, I want to keep up with him better.
ORIGINAL: MONSTARUSTA
LRP/neo 2 star is a great setup for speed. The LRP/Neo combo has slightly less torque but has way more top end.
#2555
YES!!!!!!!!!!! finaly a great excuse to use my dremel, gonna cut triangle shapes out of the chassis (that way it is still relatively strong), already got duratraxx bearing in it, on the carriers, should i change the trany ones also or no? should i stiffen up the suspension at all? you know change the springs? or just add spacers? gonna relocate the batteries to underneath with a cardboard protector, i dont wanna use velcro though, any other ideas that are easy to change quickly?
#2556
IA
Go to www.stormerhobbies.com and get a Hacker C-40 with the ESC that is suggested, you'll haul right past the Revo![>:]
#2558
IA
Set the suspension to the outtermost (I know, it's a big word!) hole and then add an 8mm spacer to each of th springs. Stock springs and oil work fine for me.
#2559
maybe, on one end, and on the other a zip-tie to hold it better, just wrap the velcro around all the way, will have pics up when i get to that part, cutting the holes this weekend, may take off the wheelie bar to loose weight[:@] thats a double edged sword though
i have heard bigger words, will do that as well this weekend
#2560
I'm no expert, but I think circles would be just as good to cut out of the chassis as triangles. Search around for info on dremel'd Stampedes and/or Rustlers. I know others have done it. That will be useful for you to learn from them. Check out this site: [link]http://www.ultimatetraxxas.com/stampede_phase1.html[/link]
Leave the bearings in the transmission, they work fine.
#2561
who sells that set up?
You could get a lehner basic 5300 and a O.K. esc off Rcmonster and totaly smoke your dad and It would only cost like 250.
#2562
guess what they make a 6 turn 7 turn and a 8 turn, out of all 3 right now.
ORIGINAL: ReedyMan
#2564
if i went with the lehner 5300 motor, would the warrior 7020 be a good esc?
all of these would be around the same price. from $253.00 to $298.00
if i went brushless i would need the metel idler gear i guess $13.00
and what else? ball bearings, rpm carried for bearings and anything else?
#2566
Thats the esc you was going to get?
Thats what I was going to get. Also people I've talked to say they've ran hacker motors of equal power on that esc but no promises.
#2571
I dont think im going brushless yet, I have the money I could but i need to upgrade parts for it first, i might just buy another pede or rustler to bash when the ohther is broke.
Still he says he doesn't what novak. It runs hot! and is slower than a neo unless you run a 4.5r which makes it run even hotter.
#2573
lol, well like i said i really need to upgrade other stuff first like upgrade to the rpm carriers and bearings and yokes and stuff like that. cause it wont handle the brushless power .
Come on upgrade what you got they aren't fun tell you got some money in them.
#2574
ORIGINAL: trckey2
ah, i remeber fom my egineering class in highschool that triangles where stronger, so i figured that those would stil leave it plenty strong
#2575
ON, CANADA
Hey guys,
I just bought a brand new Stampede with ESC, and I was wondering if anyone could answer a few questions.
First. How can I get more runtime?
I'm using a Vision Peak 2 charger, and a Pole Position 6-cell 3300mAH battery.
Also, should I be charging it on 2 or 4 amps?
Second. What are some of the first upgrades im going to need on my new 'Pede?
I've already started on a skid plate and front bash guard, and am going to buy a wheelie bar for the back. But, I need some performance enhancement.
Thanks!
Thanks!
