RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
problem with rusty HELP!!
Old 04-09-2005 | 03:59 PM
Default problem with rusty HELP!!
Well i installed a new Servo yesterday i dont think it is the problem but, i have a Duratrax ESC
As you can see there where it plugs into the receiver well every time i turn it on the light on the ESC wont come on and it wont run or anything i have to like unplug the plug from the ESC to the receiver 2-3 times then it comes on but still after i run it for a few minutes it jus t stops. Should i send it to Duratrax? Suggestions?
Old 04-09-2005 | 04:02 PM
Banned
Default RE: problem with rusty HELP!!
make sure, ur radio batterys r fully charged!
Old 04-09-2005 | 04:16 PM
Um my batts in my radio r fine it works sometimes its like it has a short in the wires or something idk maybe some of the smarrt ppl on here will know.
Old 04-09-2005 | 04:56 PM
My Feedback: (82)
You might try looking at the wires in the plug that goes into your reciever. Make sure the little tabs that hold each wire in the plug is clipped in right. Sometimes these work loose a little and will cause the whole system to glitch. First I would try unplugging the steering servo, then see if it all works normal. If so then it is your servo wire, if not look at you RX plug wires on your esc. I have bought a few servo's that needed clipped into the plug better, and had the same problem. And make sure your car batt is charged (for esc power assuming your running bec) Hope this helps
Take care,
Jay
Old 04-09-2005 | 05:11 PM
thanks for the help but ive tried it all. i guess ill send it back to duratrax
