Why won't my wheels work?
Banned
GA
I just got new wheels for my evader st and they're rpm starz and they dont move when I tighten down the nut. Whats the problem?[sm=confused.gif]
TX
RE: Why won't my wheels work?
Front or Rear wheels? I notice that if I tighten the nut to far on my XXX-T's fronts, they will not spin. I just back the nut out a 1/4 turn then it's great. Try that and see.
TX
So they won't spin correctly even if the nut is off? If you have the bearings inside the wheel, check them, maybe you have one in there crooked.
TX
Ok well do you have the Bearings and spacer installed inside the wheel correctly?
Only other thing I can think of is that maybe you don't have the washer that goes between the wheel and the nut.
Banned
GA
I've tried everything. I put the washer in the inside of the wheel and now it doesn't bind until i tighten it fully so this may be ok.
makr sure the small lip kidna thing on the spacer in facing onto the bearing, and tighten it up fully, then back off 1/4 to 1/2 a turn.
Banned
Sounds like the wheel might be hitting the tie road. My T4 had the same problem with the Jaco wheels. I ended up shaving 1/16" off the wheel and it worked for me. That's easy with a foam tire, not so easy with a rubber tire.
