The Evader Coalition ~ T.E.C.
#426
CA
RE: The Evader Coalition - T.E.C.
The gear box is cheap but you have to find out why it broke.
http://www2.towerhobbies.com/cgi-bin...?&I=LXAMG0&P=Z
#427
CA
Cantavader Update...
My XXX-S Rear Shocks aare the exact right length... Yes!
Yes that is an alan wrench holding the turnbuckel to the cardboard... that will be a nut bolt and carbon fiber later on
Bad news is I need longer turnbuckles because the ones I have right now that are hooking the upper part of the steering knuckle to the bulkhead (This ajusts droop now... yay) they are at the maximum length and the arms are level... not too good for the basher...
#428
ORIGINAL: raz54
#429
ORIGINAL: true2blue92
I think sumthin is broke? I was driving my evader and all of a sudden it started making this really loud clicking noise. So I took everything apart and the tranny was cracked on he side. So is that the problem? ALso bout how much are new ones.
#432
GA
#434
CA
ORIGINAL: Doahh
Crunk I know mine goes 35 at least but SAEs vader did 68 confirmed
Doahh, are you sure that's not 45 mph? Mine goes 34 with a cheap brushed motor and your's has a bl motor.
#436
just got back from a good bash session uploading vids now (sucks since my camera is down using my lil sis camera and it only takes 1min vids)posting here in a few
edit
anyone know a good easy to use movie edting program i can download online
edit
#437
here they are can someone anwser my ? above about a good editing program id like to turn all these into one good vid instead of a bunch of short ones
http://www.rcpics.net/img/73747
http://www.rcpics.net/img/73748
http://www.rcpics.net/img/73749
http://www.rcpics.net/img/73750
http://www.rcpics.net/img/73751
http://www.rcpics.net/img/73752
http://www.rcpics.net/img/73753
#438
I got my side windows sprayed yesterday. They look pretty good. For the winsheild should I go to the top or mask off at the little bar above it? If you understand what I mean.
Here are some pics of my body. I contoured the corners perfectly. lol Hard to do with regular painters tape. I used little pieces on the corners and pushed the tape away with a pen clip thing.
I will have to get pics of the body on the car after the windsheild is done and I replace the rear toe-in block.
#442
tamiya ~ Does your camera have a macro mode? It is so the camera focuses correctly for close up shots. When you use it don't use the flash. It throws off the focus and quality. Find a bright room or lamp to use instead and hold the cam. very steady or set it on a table.
#444
MA
Ok after 3 days of ownership of a new Duratrax Evader I have to say this ST is a POS, being the first RC car in my house I have nothing to compare it too but if this is what the industry is putting out they should be SHOT! First the transmission support, then shock towers, then shock ends, then the steering servo[:@] Now I had a burned out HiTec servo from my boat and took the gears aout and swapped them for the damged ones and for whatever reason the servo will not re center, and if you bump the tires into anything it gets out of whack and you need to trim to get the wheels straight, also how does anyone get the servo saver adjusted right ??? Frustrated I guess, I don't mind wrenching on stuff but when you wrench more than run it is no fun. I can only hope my FG ST will be much better in the reliability dept
#446
Sounds like he got a bum evader to me. I never had that many problems at all.
You should try sending it back or something.
#447
CT
umm....i have a evader st with a 15 turn in it with the stock ESC and it doesn't even get hot...i broke the rear arms finally...lol...so i had some extra team losi XXX-t rear ones so i put those in it with some 1.5 MM spacers...fit wonderfully....lighter too...i have a hole cut in the body for More air flow and Hpi star rims and some losi pin tires in the rear....very nice truck...i like it alot...very quick and good durability...i like mine alot...also a custom made rear shock tower...i work in a machine shop
#448
hey humphrey - do you get your parts over here or get them in from the US?
[link=http://www.radiomodels.com.au]Radio Model Supplies[/link] they have some good stuff and their web ordering is quite good. check it out anyway. You should also have a hobby shop in Brisbane that you can most of your stuff from.
Anyway I'm back on the road now with some new parts will try to post photos soon.
#449
TBOLT whan replaceing the tranny brace dont buy a stock plastic one i went thrue 3 before i bought the alum one ahvent had a problem since also u might as well get the front hinge pin/sway brace alum to thats the only other part ive reall had break allot
had a few other breakages but they were from jumping a car and a few other things(my fault
#450
Here are some photos of the new parts, they include new front bulk head and shock tower ball cups and battery brace. Looks a lot better with those yellow ball cups. Has any body had any experience with the Novak GTB system in an Evader. If this has already been discussed please direct me to where.
Anyway hoping to get some action shots this weekend. If I do will post some photos.
