RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
The Evader Coalition ~ T.E.C.
Old 01-11-2008, 04:06 PM
  #8701
cheech4
cheech4's Avatar
Default RE: The Evader Coalition ~ T.E.C.
ORIGINAL: beandog
the directions with the ext say to only use a 6 cell battery has anyone ran a 7 cell for a while now wiht out problem?
I dont own an EXT but you can run a 7 cell, just remove the foam thingy under the rear shock tower the 7th cell fits under it... only a odd shotgun style 7 cell can work, unless you want to mod the chassis and use straps.
Old 01-11-2008, 09:59 PM
  #8702
J-Cube
J-Cube's Avatar
Good news! The DX3R will soon be shipping from Horizon Hobby! My 2.4 GHz radio is finally coming!
Old 01-12-2008, 08:46 AM
  #8703
XPFTP
Tazer 12T FWD/REV ESC anyone useing this ?? and pushed it a bit ? lookin for a good ESC for a fair price and tec and others are a bit high ...
any ideas would be good.. i would like to run probley around 12T and up brushed...6 to 7 cell .. or a good site for nice priced brushless motor and ESC.. or ideas on witch company for brushless.... thanks ..
Old 01-12-2008, 09:00 AM
  #8704
Frozen72
Frozen72's Avatar
I would get a 13T motor if your going to use 7 cells. A few people at my track use that ESC with no Problems. I'm going to get mine in a week or two with a 13T motor.
Old 01-12-2008, 02:32 PM
  #8705
Fire106
Hey guys,
Ok so instead of doing a nitro to electric conversion I did some trading with a local guy and got an old electric evader. It has the stock speed control and a "atomic force" 17 turn motor. Now its time to upgrade!!!
This is my first electric truck so im trying to learn as much as i can before I buy stuff. This is just going to be a basher so i dont want to spend too much......but i would like speeds in the 40's.
Im going to go to my LHS today to see if i can get the B2 diff and rings.
I know a lot has been posted here about motors and esc's. trust me....im going to read all i can
I have about 150 to spend on motor/esc. any suggestions?
Old 01-12-2008, 04:42 PM
  #8706
cheech4
cheech4's Avatar
ORIGINAL: Fire106
Hey guys,
get a brushless novak XBR 8.5 with 7 cells it should get 40 mph and it cost about 150 after the 25 dollar tower coupon... and NO MAINTENANCE, Great ESC for brushed motors too it has no limit.
heres the link..... 169.99 minus 25 tower coupon = 145$ cant get better than this
http://www3.towerhobbies.com/cgi-bin...&I=LXRST1&P=ML
Old 01-12-2008, 04:59 PM
  #8707
chriswebb70
In my attempt to make my Evader as fast as it can possibly be (and to show I have too much time on my hands), I've come up with this:
I'm using an LRP 9 turn motor, mounted to a 35 tooth pinion - 78 tooth spur gear combo. I found a used Intellispeed 8T ESC on Ebay cheap (Ebay is great!). Re-did all the wiring using Deans WetNoodle. There is a huge voltage drop when I accelerate heavily (the ESC can't take it....it momentarily shuts off), so to combat the voltage drop, I added a BEC box (4AA batteries). It seems to have solved the problem; the Evader still accelerates fairly quickly for such a large pinion.
I don't know how fast it goes (wish I had a radar gun), but it is quite the road missile!
I've got a 70 tooth spur gear coming later this week. Surprisingly, the motor seems to be handling the gearing well. Hasn't gotten hot or anything.
ID:	849262   Click image for larger version
Old 01-12-2008, 08:52 PM
  #8708
chriswebb70
The 35-tooth pinion, 78-tooth spur gear works well, but I think I can get a little more oomph out of it. I'm going to try another gear; a 20-tooth pinion, 81-tooth spur combo. The 35-78 combo ran fast, but took forever to get up to high speed.
Old 01-12-2008, 11:01 PM
  #8709
Fire106
Thanks for the suggestion Cheech............ I have looked at a few different set ups. I am thinking about one of these 3
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=001108564&I=LXRST1&P=K]Novak xbr[/link]
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNKU0&P=7]Mamba Max 4600[/link]
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSDB8&P=ML]Velineon[/link]
Do you guys think the B2 ball diff will handle these? Or should I try and convert to the EXT diff gear?
This is just going to be a basher for me.......once i get it all set up there will be plenty of video
Old 01-12-2008, 11:17 PM
  #8710
chriswebb70
I'm thinking about brushless too. What's the difference between the Mamba Max 4600kv and the Mamba Max 7700kv?
Old 01-12-2008, 11:22 PM
  #8711
rymansl2
rymansl2's Avatar
Hey everyone. I just recently purchased an Evader EXT. Wanted to own a nice rc car for once in my life and decided to go with the EXT because of the durability i've read about, and you can't beat that price! First time I took it out the rear axel broke on one side (but it was because of a defect in the part). After I replaced that part the front shock tower and body mount broke on it (once again, I think it was a defect but who knows). So much for stress-tech, haha. I bought a graphite version of the front strut tower to replace it so all should be well. Other than those two things its been a bad azz little truck. It handles jumps and bumps very well. I love the thing. Even 20mph seems amazingly fast. I'm sure I'll want more speed out of it in time so I'll probably eventually upgrade to a brushless system, but only once the stock motor burns out. I say don't fix it until its broken, lol.
But anyways, I have one main question. I've read in this thread many times about how the EXT comes with bushings instead of bearings. So whats the benefit of bearings and is it really worth the 15 dollars? If it really doesn't make a huge difference then I'll probably go with my policy of don't fix until its broken. Cause I'm sure the bushings will wear out eventually.
Old 01-12-2008, 11:31 PM
  #8712
JMHZ2401
ORIGINAL: Fire106
I just bought the Velineon (today) and love it sooo far!!!!! man this thing fly's!!!!
Oh it has been a long time since I posted. Life has been busy as well as work. The Evader has been doen without a motor for a long time. Duid not buy another brushed motor because I wanted brushless. Was going to go with Mamba, but the Velineon was really nice and nice price. I do have to rebuild my diff, but ti is the orginal diff, which is about a 1 year and half old with lots of track time. It was needing rebuilt before the new set-up. I plan on being on the board more and having some video as well.
Old 01-13-2008, 01:37 PM
  #8713
chriswebb70
rymansl2,
Bearings make a world of difference! Spend the $15 and get a set of bearings for your EXT. Your speed will increase.
Old 01-13-2008, 01:45 PM
  #8714
Frozen72
Frozen72's Avatar
I might save up for a few more weeks and go BL instead of getting a 13 T motor. Would the Valeion or the XBR 8.5 be faster on 6 cells.
Old 01-13-2008, 05:13 PM
  #8715
Fire106
I love EBAY I just got a Mamba Max 7700kv brushless system for $153.50
I guess im gonna have to beef up that trans huh?
Old 01-13-2008, 05:47 PM
  #8716
rymansl2
rymansl2's Avatar
ORIGINAL: chriswebb70
rymansl2,
Alright thanks. I'll def. consider it. My brother just bought a Rustler xl-5 so I may need to do something to keep up with him
Old 01-13-2008, 07:55 PM
  #8717
cheech4
cheech4's Avatar
ORIGINAL: Fire106
yah!! b2 all the way, and alloy nitro evader idler.
Old 01-13-2008, 08:16 PM
  #8718
Frozen72
Frozen72's Avatar
What are some other gear covers that will fit the Evader EXT I cracked my stock one and stripped a spur because of it?
Old 01-13-2008, 08:29 PM
  #8719
cheech4
cheech4's Avatar
ORIGINAL: Frozen72
well your holding the bag on that one. they dont make different ones. but you can do something to make them stronger.. i sprayed a few coats of PLASTIDIP on it and it works pretty well.
Old 01-13-2008, 09:01 PM
  #8720
EVADERCHAOS
EVADERCHAOS's Avatar
Old 01-13-2008, 09:04 PM
  #8721
cheech4
cheech4's Avatar
oh my god its him!!!!! he has arrived, the icon, the man, the founder of the TEC..... whats up EVADERCHAOS ????
Old 01-13-2008, 09:19 PM
  #8722
EVADERCHAOS
Heyoo!
So the story goes, I got a PM from someone on RCU a little while ago and something went *BING!* and I remembered TEC. hahaha
Yeah the ole Evader is just chillin in my garage right now, hasn't been touched in almost a year.
Finally got a nice job, about to be out of school in a few months and my desert life just keeps getting bigger. I had been wanting to sell my Evader for a while but now Im kinda wondering if I want to take it for a quick spin. lol If someone knows anyone who wants to buy, let them know (basically RTR with everything you need including batts, charger, spares and toe brace kit (racer), if not I may sit on it for a while longer. Im afraid that if I want to keep it then thats a few hundred that I won't be investing in my truck's suspension because I'll want to start upgrading the R/C and whatnot. hahaha
So what all have I been missing out on in m absence? What's this EXT? lol
Old 01-13-2008, 09:27 PM
  #8723
cheech4
cheech4's Avatar
cool dude, its nice to see a VET once in a while. i know how you feel about selling RC, i too get that way also. as far as the EXT its basically a basher version of the evader. it has better plastics and fixed the evader tranny problems,its a geared tranny instead of ball diff. few things have been downgraded but not so bad in my book. the shocks are plastic and theres bushing instead of bearing, lastly it can handle brushless with no problem with the new tranny and for 99 bucks RTR and the 1 year warranty what the heck else are you going to expect. anywho nice to see you drop by dont be a stranger.
Old 01-13-2008, 10:38 PM
  #8724
Fire106
So is anyone running the Mamba Max 7700kv?
Any words of wisdom??
Im gonna hit the LHS tomorrow and see if i can find the B2 diff and shop for some batteries.
Old 01-14-2008, 12:18 AM
  #8725
cheech4
cheech4's Avatar
ORIGINAL: Fire106
i have the 6900, and a few friends who have the 7700, what do you need to know?
