The Evader Coalition ~ T.E.C.
Banned
VT
RE: The Evader Coalition ~ T.E.C.
idk, its from a crappy no-name nitro
but i have a HUGE PROBLEM!@!!!!1
sometimes the motorspins, but the tires dont, im a total noob
any help please?
any help please?
OK
ok check your pinion and spur gear 1st. make sure the pinion is on the motor shaft good and tight there is a set screw on it that you tighten and then make sure it is makin contact wit spur gear
Banned
VT
they both spin, spur an pinion, ive toyed around with the slipper clutch, not sure if im doing it right, but sometimes it catches, but going uphill or on grass it loses its grip
finally broke something today...[X(]...[sm=lol.gif]...the antenna tube-lol
question,in this pic you can see how high the front a-arms sit.it has kind of a "nose high" stance,which i think contributes to it's "fish-tail happy" handling characteristics.is this the normal stance,and if not,how do i lower the front a little (adding pre-load clips to the shocks obviously raises it)?
thanx!
thanx!
ORIGINAL: nitrozach54
bummer[]
bummer[]
too bad i'll end up making a 50+ mile drive to the lhs next week for a 25 cent part tho-lol
NY
truthfully i hate when antenna tubes break, it exposes the wire for damage. and if damage accurs then the radio will go out of wack causing the truck to go nuts and crash. ( assuming you dont have a safety switch that is ) lol
ORIGINAL: cheech4
evaderkid,i'm not sure,but seems like the ext would be a better candidate than the standard evader because of the gear diff.
Banned
VT
ORIGINAL: dragon2k2
do they spin together when the motor is running? Does your tranny make any wierd noise like one of the gears is stripped?
FL
thanx!
thanx!
Banned
VT
is someone gunna help me?
i dont know what to do, on the stand the wheels spin, but on the ground spur and pinion spin, but the wheels dont!
what do i need to do to fix it? do i need to replace parts?
NY
double post, sorry[:'(]
NY
axels look fine, i think the slipper is ok, i screwed it in all the way, then brought it out two turns, like the video said to
Banned
VT
I looked and my idle gear is stripped.
I read somewhere that motors dont last long, what should i got for a good brushed motor?
NY
ORIGINAL: cheech4
you have the stock ESC on the evader ST... then get either the Trinity CO27 pro motor, or the Team Orion Core motor... there both 27t motor but you will see a nice speed difference compared to stock.... ALSO i have heard it is the regular ST Stock ESC that people were able to run a 19T motor, in that case i would recommend the 2007 Team Orion ELEMENT motor, the 2007 Peak DYNASTY motor ( same motor really ). Those are my first picks, then also the Team Checkpoint MONEY motor and the Trinity komodo dragon motor.
VT
ORIGINAL: cheech4
heres a mod i said i'ld post a week ago but never did...
pic one: the screws that hold the things that hold the rear A arms on well for me said screws come loose alot and i know it must wreck havoc on somthing so i figured how can i get these to stay one
pic 2: easy bolt um on good and add a bit of locktite i will say that the back to bolts did need to be dremeld a bit so the tranny case could fit on
the lug
Banned
VT
ORIGINAL: fullauto4u
I run the Trinity C027 pro, in my Evader BX, it way faster than the stock motor that came with the buggy. I think it's a good choice for a upgrade.
ORIGINAL: cheech4
what are T's? what do they mena, is higher t or lower T better?
VT
t's are turns or winds on an electric motor, the more t's the slower the motor will go but the more torque it will have the higher # of t's fast more amp draw and less torque, now some motors are better than others so a really good 27t could be better than a 20t,
random fact 27t is considered stock 19t is mod... for racing
the lug
the lug
