The Evader Coalition ~ T.E.C.
VT
RE: The Evader Coalition ~ T.E.C.
they should bolt up just fine, and i haven't seen a pic with slash but here's a pic MC did with blitz and those adapters
looks pretty sweet IMO...
the lug
the lug
My Feedback: (8)
ORIGINAL: msdtyu
is there a way to change from the weird pin system used on the ext to hubs like on my merv? or is the pin a common way of mounting wheels on the ext? (lol im new the stadium trucks sorry)
You can use 12mm hex wheels like traxxas,hpi
edit : boy was I late lol
WI
Hey Guys I have a question I bought some pl Edge tires and am wondering which side is out as on side has 2 ribs facing same direction and the other side has 2 ribs back to back facing opposite directions I believe the latter is the inside as it has sidewall that extended onto the footprint of the tire
My Feedback: (8)
There is no wrong way to mount them.
They are mode for 2 diffrent track conditions.
the double groove goes inside for loose condition and outside for high traction
My Feedback: (8)
actually there is a wrong way to mount tires.
I use the jconcept mounting thingys. Black tape works just as good
But once you glue one side of the tire. Wrap that side of wheel and tire with tape and allow to dry.
My Feedback: (8)
ORIGINAL: Dark asylumn
okn thanks now the double grooves are they the ones bback to back touching or facing same direction and a gap between them
/ \/ \/ \\\>outside. Less aggressive steering
edit : from someone who has used them
Single blade for more aggresive steering
I really regret getting the vader at hobbytown. It was more expensive than on tower and i have a crappy charger which has a timer and has a fixed amp rate. The charger was 45. Then i got a 2000mah battery for 20.
I should have waited for the new vader and the knowledge of tower and how overpriced things are at lhs's.
I have no idea why i said this.
My Feedback: (8)
ORIGINAL: Crapxxas19
You live you learn
My Feedback: (8)
ok here is the EXT ready to run again
Was it hard to dye them ?
My Feedback: (8)
Can undergearing a brushed motor be bad.
My Feedback: (8)
Hose down the shell and just wipe everything that you can with a paper towel and its good enough.
WI
ORIGINAL: mc4798
have to ask
How do those badlands do on loose sandy conditions ? They look so meaty
have to ask
Ihave no Idea on the ext, on the eraze when it ran for the few minutes it had no problem hooking up with tire on the rear only (badlands) remember Ishredded the fronts instantly, but it seemed to hook up. Iwill get video if it running Ihave to make some new longer wheel pins before Itry though
VT
i ran my badlands in a little bit of sand not much to say much either way but they were pretty good, but it wasn't much to go by....
dark, did you dye the wheels with the tires on, or are those first pics of them unglued?
the lug
the lug
QC, CANADA
ORIGINAL: mc4798
nothing like morning mud [img][/img]
now need somebody to cleanem up
have fun cleanning [sm=wink_smile.gif]
Will drop by my LHS today to see if my losi wheelie bar set came in, then will install and post pics..[sm=teeth_smile.gif]
