The Evader Coalition ~ T.E.C.
#2451
NY
RE: The Evader Coalition - T.E.C.
raz i bought it from a guy who bought the dx3 and only had 1 car, so he sold the extra receveir to make a buck. it was brand new. i tried binding them, it doesnt have a problem with binding.
#2452
My Feedback: (29)
IA
Hmmmmm, Well I would call Skektrum customer service. They have always been very helpful when I called them.
And don't try to BS them about how you got the RX. Tell them the whole truth about buying it on E-BAY. Believe me they don't care where or how you got it. They will not treat you any differently then if you bought it directly from them.
Ron
Ron
#2453
CA
cheech. Just so I understand correctly you think it is one of the rx's that's causing it? Has the antenna wire been cut? They say you can cut them as long as you leave about 3.5 inches. How long is that one? I didn't cut mine, I just coiled it around the shortened antenna tube
#2456
KY
a few more questions here.... are any of you all running 2.2 tires? and if so what hex adapeter are you using if any? from what i know most 2.2 tires have a hex, i wasnt sure which one would work.
also what are the pros/cons of switching from the 88t st spur (which i have now) to the 81t bx spur? i am running a intellispeed 12t with reedy flash 13t motor and stock tires now.... wouldnt it be a lot quicker? if i were to get the larger 2.2's would the bx spur pose a problem?
also does anyone make 1/10 foams that would fit on the evader? i hear there is a carpet track in spain (our first stop on the way to iraq) thought i might check it out.
well any input is good, thanks!
#2457
NY
no i never touched the antenna left it just as is, and no i dont have a after market fail safe, just the one thats installed in the spektrum.... i called them today and yes your right they are nice and he said no matter where i got the rx that they will service it. i knew that wasnt the problem the problem is i bought it privately and i have to spend more money on it.
#2458
My Feedback: (29)
IA
I know what you mean about having to pay more, bummer. BTW how much did they ask you to send with it to get it repaired? Before you send it in I think you should open the case, get a good magnifying glass and look at the solder joint where the antenna wire is connected to the board. You might be surprised at what you find.
Ron
Ron
#2459
NY
they didnt give a price they just said bring it in.. i talked to the guy who sold it to me and he said that he had his serviced and all he said was he bought it new but lost the receipt and they fixed it for him.. yeah i bet they did, its problably the one he sold me!!!!...
#2461
NY
Made a mistake on last quote. I did open it and it did look good the solder. Because it was my good receiver, the other one the bad one the antenna seemed like half the threads were disconnected or ripped out looking really close at it. I dont know if that would create my problem im having. so i ask should i solder it my self and risk that it would work again or just send it in ???? my soldering is not that great so if i touch it then send it in they can tell i touch it. so i might void it. anythoughts????
#2462
My Feedback: (29)
IA
I think you found the problem. If you are not real confident on your soldering (I know I would not try it) take it to a local radio/tv repair shop I bet they would resolder it for cheap.
Oh, and "YES" if there are loose threads in that wire/solder joint they could cause intermittent problems.
And when you put it back together use the side hole for the antenna wire. Now that you have seen the inside you can see the strain relief that is provided in the side hole.
Ron
Ron
#2463
CO
I need the wisdom of this group. Can anyone tell me in layman's terms what the pros and cons of serrated vs. non-serrated brushes are? Anyone have a preference for one over the other?
Ed
Ed
#2464
CO
ORIGINAL: 4 stroken ron
John
#2466
ORIGINAL: SpecialEd
Ed
Ed
I personaly break-in my race motors for about 10 - 12 min @ 2v. There are different types of serrations for different brushes, for example The Trinity E-brush (4499) has smaller serrations than a Reedy 767. The 4504 is the same brush as the E but the serrations are diagonal. I really like this brush because it doesn't cut grooves into the comm and stays cleaner.
Non-serrated brushes take longer to break-in and conform themselves to the shape of the comm. I personally prefer serrated ones.
Performance wise, I like the 4504 and the F-brush. They hold up pretty good for the stress we put them through in Touring car. This is a more racing oriented point of view from my On-road experience. For Off-road buggies like the Evader they should last a good while. How long I honestly don't know, I'm new to Off-road and got the Evader just to play around, but motor temps in On-road are a lot higher than Off-road and the motors don't get beat up as bad. For playing around purposes you will not see any difference.
If you don't race, you will not notice any difference. Just use the ones that you feel last the longest.
Hope this helps.
Joel
#2467
WI
motors don't get beat up as much off road? what about when they slam into dirt or sand while doing a wheelie or go through mud water> and the constant dust, and big tires? how can you say offroad doesn' get abused as much
#2469
ORIGINAL: skidooguymxz550
#2470
ORIGINAL: SpecialEd
SanabriaJ - Many thanks for this wealth of information. I hope you enjoy your Evader now that you have it.
#2471
NY
well i tried soldering it and all the threads are in. my job soldering is not a profesional looking job but it is perfect to me,hopefully this fixes the problem. not for nothing though the servo i have in there now is the replacement for the broken servo and its the spektrum servo not the metal high torque one, i love that one but the other it comes with the 270 i think it is, its a piece of crap no torque and its slow.. but i do have to say that it still turns the wheels when i start it, will it freak out when i drive it we will soon find out.
#2474
NY
anybody know anything about these servo's, there pretty cheap. and they are metal geared high torque??
[link]http://cgi.ebay.com/High-Torque-Metal-Gear-Ball-Bearing-Servo-MG-995-US_W0QQitemZ220002602716QQihZ012QQcategoryZ34056QQ cmdZViewItem[/link]
#2475
My Feedback: (29)
IA
They are a little slow, but not too bad. Price is right and I believe Tower Pro servos are OK. If I needed any right now I would order them.
Ron
Ron
