Battery help please!
AR
Sorry for the dumb question, but I don't have time to do a search. Is it absolutely necessary to discharge NIMH 6 cell batteries? What will happen if I don't discharge them?
RE: Battery help please!
As far as I know it does not hurt the life of your NIMH packs to leave some charge on them. With Nicad packs it's a definite no-no.
PA
Here's one of the best guides to battery care I've seen:
http://www.specpointbatteries.com/ht...tery_care.html
Banned
No, But it does help performance wise.I usally use a bulb discharger WITH a 5.4 volt cutoff to discharge after a run.Then I tray it to .8 a cell.Hope this helps.
ORIGINAL: SpunkyBBR
cell reversing you mean? yes there is, but depends on many factors. any way, just discharge no lower than 0.9v per cell [5.4v for a 6cell pack]. by the way, nimhs already have a self-discharging rate of 2-10% of their capacity per 24hours [also depends on storage conditions and cell quality].
ORIGINAL: kostaktinos_mt
what happened? there are several reviving processes, but i need details to recommend any of them....
maybe try letting it charge thinking it's a 1-cell, then try again after that. I don't know for sure, but that's what I would try.
trickle charge for at least 24hours. if you have another charger [low-end] it is preffered to use that for this process. if the brain977 has manual mode, enter it and set the charge for 6cells. you will at least 24-48hours of slow trickle charge at 100 or 200 ma rate for the cells to start to revive. then it would need 4-6 cycles of scaled charges/discharges: 1amp charge rate then 1amp discharge rate for the 1st cycle, then 2amps charge rate/2amps discharge rate for 2nd charge, etc,etc. 4cycles minimum to reach 4amps charge rate.
