Check out this set up aight!
Lol this is my set up im getin for my pede, i need the esc and crystals for another truck but im using the esc in my pede as well. But yeah here it is. I want to get another pede i had one but it got stolen (over 500 dollars worth of hop ups). I love the pede, its light and it has a fair potential to be a crawler and just a great mt as it is stock. And dont any of you people tell me a stock pede cant crawl. It can. Verry well to an extent. It has about the same capabilities as a 7 inch chassis lifted chevy 1500. and i respect that about it lol. Ok to the point sorry i got off topic. Here is the link but also heres the list of stuff.
LXVK75A6 Traxxas Stampede RTR w/Radio & ESC A6 27255
Accessories Needed Combo Available
LXD523 DuraTrax Streak Forward/Brake Hi-Frequency ESC J
Team Orion 15T Double Method Motor
Traxxas Pinion Gear 48P 25T
Traxxas Body Clips (12)
Epic 6-Cell 1500mAh NiCd Sport Battery Pack
LXEX10 Robinson Racing Pinion Gear 48P 12T
LXJM14 Traxxas #1 Crystal Set Brown 26.995
That is the set up, i want to know if it will be able to do dead stop wheelies with the orion motor and the 12t pinion. Like i said, im using the stock motor, esc, and them brown crystals for a roller chassis i got. But other then that i just would like to know what to expect, also what speeds will i get with that 15t orion motor+the 25t pinion+the esc. im not expectinmg much, hopefully 25 ish. I just want to have the extra parts so if i want to have mad speed or mad torque.
RE: Check out this set up aight!
look, with that 25t pinion, the 15t motor will burn out flat! don`t try it. you may use 12-15t pinions with that motor and with the 87 or 89 tooth spur gear along. with the 15t pinion, you should get 30-33mph BUT NOT WITH THAT PACK. you need a better pack. as for the rock-crawling capabilities, the stampede can`t crawl [my opinion]: limited articulation, limited suspension travel, small and not grippy wheels [the traction sucks], and [most of all] 2wd. its the last truck i would consider a rock crawler. anyways, i own one and i love it! its one of the best 'bang for the buck' basher trucks in rc...
I know, i was saying its just as capable as the chevy like a real one so its kinda sorta scale. but yeah, what about the 75t spur with a 12t pinion? and what gearing for the stinger?
My Feedback: (18)
well, the parts are all stated above so that helps i think and what is in my cart is what is what im buying
What pack should i get, illl throw down the extra bucks i guess. I wont have my mula till the end of march but when i do have it i will have around 500ish
i recommend staying with the stock spur and a 14t/15t pinion for that motor. also buy a 16t one for more top-end at cold days...
the stinger is junk [as well as most rtr motors]. it will overheat even with the stock gearing, but will also overheat no matter what you do [lol]. stay with the stock gearing for the stinger.
dang fast reply...read up because we posted within 1 minm of eachother and i dont know if you saw what i wrote
from tower: smc ib3800s, 35$ each, pretty DAMN good performance and runtime...
otherwise go to boomboom... their zapping process is pretty decent from what i hear...
you mean to tell me that milliamps actually give more speed, i thought that all they where was longer run times the more you have. I thought you where talkin about a 7 cell or sumthihn
well i guess i learned sumthin
no. the mah is rated for capacity. 'punch' [aka: acceleration and amp-draw tolerances without compromising the voltage] and top speed are factors mainly based on voltage AND IR [internal resistance]. it happens that most high-end packs [such as ib3800s] have WAY less IR than cheap packs [no matter the capacity], thus allowing for very impressive performance increase. however, its just an indicator. i have some 12year old sanyo scr1400s which will own any non-zapped non-matched 3000mah nimh every day of the week...
yeah, it didnt like actually go in it just like hit my eye the actual eye thingy..it hurts like a motha lol.
MA
I suggest you get this:
http://www2.towerhobbies.com/cgi-bin...=LXJE66**&P=ML
http://www2.towerhobbies.com/cgi-bin...&I=LXLHE2&P=ML
http://www2.towerhobbies.com/cgi-bin...&I=LXFBH5&P=ML
and IB3800 from boom boom
for crawling these tire: http://www2.towerhobbies.com/cgi-bin...?&I=LXUM92&P=7
and this chevy body: http://www2.towerhobbies.com/cgi-bin...?&I=LXDVK0&P=7
(the body might be a bit big but tower didn't have any pede silverados)
