deans y-adapter battery diagrams
ON, CANADA
I have been going insane the past 45 minutes searching the forums and google for a diagram showing how to make a deans y-adapter for connecting two batteries together in both a series and parallel.
I found a real good diagram a few weeks ago but I forgot to bookmark it and can't find it
Does anyone have a diagram showing the steps needed to make these y-adapters?
My Feedback: (16)
CA
RE: deans y-adapter battery diagrams
No, you don't need a circuit board to double runtime. There are two ways to hook up two or more packs...series and parallel. Hooking up packs in series increases voltage while hooking up packs in parallel increases runtime.
Here is a diagram for running in PARALELL
Thanks to jakjr in [link=http://www.rcuniverse.com/forum/fb.asp?m=2667496]this thread[/link]
and in series
From [link=http://swami-rc.com/tips.htm]Swami-RC[/link]
and in series
ON, CANADA
thanks ibrakefornobody!!! that's EXACTLY what I was looking for... swami-RC must have been where I saw it last week...
thanks again!!!
thanks again!!!
keep in mind that wiring two packs in parallel could be dangerous. the packs must have identical specs and should be charged equally when wired in parallel. otherwise, even a small voltage difference between them [not only at the beggining but also towards the end of the discharge/run] could cause what has been known as 'ring bridge current leak', aka: one pack charging the other one. the more that difference is, the larger the ring current flow. if the ring current is high enough, it could cause even an explosion or fire.
PS: i have used parallel configurtion many times without problems. i am just indicating the negative chances.
