Motor timeing ???
WI
Motor timeing ???
Hi Guys,
I would like to know what happens when you set the timeing forword or back on an electric motor and how it efects performance eather way .
This is the motor I 'm asking about http://www2.towerhobbies.com/cgi-bin...6&I=LXFZG8&P=K Thanks guys
CA
RE: Motor timeing ???
By advancing the timing the motor will spin faster but your run times will go down. By retarding the timing the motor will run a slower but your run times will go up. Most people either run them at 0 degrees to 24 degrees advanced
Banned
Good information above. One thing to add is that going into negative timing, below zero, is not a good thing. It produces excessive arcing and burns the motor up very quickly. Don't do it.
CA
ORIGINAL: Speedmunkey
Thanks for adding that, very good advice.
