View Poll Results: A poll
Voters: 76. You may not vote on this poll
The Official -Tamiya TA05 - Racing Thread
#51
RE: The Official -Tamiya TA05 - Racing Thread
If your spur gear is wobbling you probably blew out the bearings on the shaft or bent the spurt shaft. Take off the motor and spin the spur gear by itself. It it wobles you probably did one of those two things. If it doesn't then it may be the motor.
#52
it does the same without motor too it was doing it before i test it for first time run i didint put any motor so its not the motor`s fault .what can i do?
#53
Take apart the spur and pulley assembly. inspect all parts. You should be able to replace all of those parts individually. If the shaft is not bent then try different bearings. You can probably get the bearings at the local hobby store.
#54
i try other bearings still the same problem.now only the shaft left.how it bent without use it.anyway i order a TA05 LIGHTWEIGHT CENTER SHAFT lets see if its going to fix the problem.i have the same problem in the one ball differential pulley it wobbling like the spur.thanks.
#55
If your getting wobbling through the diffs as well then I think its time to pull the entire drivetrain apart and inspect everything and reassemble.
#56
i did 3 times that always the same problem.do you think an ALUMINUM DIFFERENTIAL JOINT solve this? i think i get a problematic model kit.
#57
its possible. not common but possible. I don't think an aluminum diff joint would fix the problem. Hard to say at this point without actually Seeing what its doing.
#58
i havent got a problem on shaft drive with bevel gears i have also a ta-04r that im not sure im going to build coz of this problems.maybe im not good on building ball differentials what can i say.where is the old good marui that i`ve seen on my childhood years why stop producing rc`s? i would like a samurai or a ninja
#59
Josh,
Keep that Duratrax speed ocntrol well vented. Mines over heated puffed white smoked and melted the casing.
#60
FL
here is my TA05, i had the original NSX body for it, and still do, but i wanted to try making a new body.
i painted this skyline body with metalic black and metallic blue. i think it looks real good in the sun, i havent put all the stickers on it yet, and i dont know if i will.
i have an atomic one way in the front and atomic diff outdrives in the back because i broke the factory plastic ones.
i have the novak ESC, but i am trying to get a better esc because i have a Trinity Cobalt 2 13T Double Round Wire Touring/Off-Road motor to put in it.
i use GP 3300 cells which with the 15t trinity speed gem motor i have in it now the run times are atleast 15 minutes if not 20. the speed is good but i am still trying to find some good tires for it, i have the hpi x pattern now, and they seem to be the best ive tried.
what do you all think?
#63
IL
I got my TA-05R and have been building it slowly - got a question. On step 22 of the manual (putting the front damper stay on, and the piece that fits over the steering assembly) I hit an issue.
With the steering assembly in place (prior to step 22), it goes smoothly and well. When I put that cover over the assembly in step 22 (part number is K1), the ball cup adjuster on the right side rubs against the cover (K1 piece) when I turn the steering by hand all the way to the right (tires would point to the right, linkage going "in" on the right side). It won't rub until I start tightening K1 down...I'm not over-tightening, it rubs well before that.
Anyone run into this? Recommendations? Thanks!
Sweet car so far. Really nice.
#64
CO
Carpet Race Upgrade Help
I have a TA05 (regular cheap version) which I bought about 2 years ago. I've never raced it but have driven it on a carpet track a few times. It is currently has all stock pieces but: a Reedy 19t Quad Mag and a Novak XRS Sport Reversible ESC (I also have a EPIC binary 2 Stock motor, both motors are relativly used). I have the cheap Futaba 2 channel AM receiver and cheap, well used steering servo (not sure which one), that came with the controller. Now for the fun part: I would like to do an overhaul on it and upgrade it to where it would be competetive on a carpet track. I would like to spend no more than $400 on parts.
What i would like to know is what are the upgrades that i should do and what price should i expect to pay for each.
#65
IL
One option might be to sell yours, buy the TA05R kit, and go from there? That kit contains a lot of upgrades, and Ultimate Hobbies has it for $220. Just a thought:
http://www.ultimatehobbies.com/istar.asp?a=6&id=TAM49418!1001
#66
Is there a big difference between the ta05r and the ta05 IFS? I like the IFS better but if the R is better then Ill probably get that one.
#67
TX
Has anyone tried the Kawada Kevlar belts yet?
Here is a link.
http://www.redrc.net/2007/07/kawada-...ar-white-belt/
Here is a link.
#69
can i have a link to the standard spur gears? like same gearing gearings fine on mine but i was wondering for the standard pitch gears if i could have a link to brands of spur gears that work?[8D]
thanks
thanks
#71
I currently race my TA-05, with a Team Checkpoint Money motor (19x1T)
in my 1st race, i came 2nd in the B final. I would have won, BUT i lost a minute on the first lap (the race is 5 mins long). The winner was 1 lap infront of me, so if i had not lost the minute, i would have been at least 2 laps in front of him
#72
Hello,nice cars guys!
-if you guys have time, please help me out a bit choosing a racer
http://www.rcuniverse.com/forum/m_75...tm.htm#7513364
#73
TX
Looks like I am going to try and set my TA05 up for carpet this season. I am going to try out some GRP foams this weekend. Will report back.
