View Poll Results: A poll
Voters: 76. You may not vote on this poll
The Official -Tamiya TA05 - Racing Thread
TX
RE: Tamiya TA05 - Racing Thread
My F103 was taking a beating running on asphalt. So I thought I would get a TA05 and race it, and save the F103GT for carpet.
________________________________
Here is my setup for stock class so far
Motor
Nemesis 540 13S (Cordite Motor)
ESC
Mamba Max
Battery
Max Amps 6000HV
Transmitter
Airtronics MX-3 75Mhz
Receiver
Airtronics Super Micro Receiver 92836
Body
Tamiya NSX
Front Tires
HPI X-Pattern Belted Pro Compound
Rear Tires
Front Shocks
The Big Tamiya Stock Spacer Only
2 Hole Piston
Stock Tamiya Dampner Oil
Stock Springs
Top Location - Inside Hole
Bottom Location - Inside Hole
Rear Shocks
2 Hole Piston
Stock Springs
Top Location - 2nd Hole From Inside
Bottom Location - Outside Hole
Spur Gear
Stock
Pinion
Stock 22T
Toe
Front - Out .5 Degree
Rear - 0 Degree
Camber
Front - 0 Degree
Rear - 0 Degree
Hop Ups
None
__________________________________________________ ___
I will change my setup here as I make the changes to the car.
Motor
ESC
Mamba Max
Battery
Max Amps 6000HV
Transmitter
Receiver
Body
Tamiya NSX
Front Tires
Rear Tires
Front Shocks
2 Hole Piston
Stock Springs
Rear Shocks
2 Hole Piston
Stock Springs
Spur Gear
Stock
Pinion
Stock 22T
Toe
Rear - 0 Degree
Camber
Front - 0 Degree
Rear - 0 Degree
Hop Ups
None
TX
RE: The Official -Tamiya TA05 - Racing Thread
I'm having a difficult time getting the electronics I want to use into this vehicle. I am trying to get an airtronics super micro receiver 92836 and a mamba max ESC into this car. Right now I have settled on putting the receiver on top of the servo. I would like to get a lower centery of gravity, but when I put my receiver behing the servo the antenna grommit touces the spur gear. I could very easily see some bad consequences if I run it behind the servo. Any idea on how to get the mamba max to fit? I could probably make a platform and put it behind the motor, but again a high center of gravity.
to be honest, RX's weigh hardly anything, so i doubt it will make a noticible difference.. cant you run it behind the motor?
TX
Lee,
I really wanted to run the ESC behing the motor. Plus I'm not so sure about zip typing the esc to the servo.
Well .... I would up cutting the chassi at the rear in order to get the Mamba to fit. I'll post pictures later.
TX
I ran my TA05 stock this weekend. I installed the Nemesis 540 13S and it was a great choice to race against other 27T motors. I did have the slowest car down the straight, but a diffrent pinion will fix that. Overall I was really happy with the performance of my car.
I started with the stock set up and the large spacer on front and rear shocks. I was also using the 2 hole piston and stock tamiya oil. For tires I was running the HPI X pattern.
The TA05 really hooked up well thru the turns and I consistently placed 2nd all day.
I found a really good curve profile for the Mamba Max and a solid setup if anyone wants to download it let me know.
I have a TL-01, but really wanting to get a TT-01 for playing around with...
I dont like the way the TL-01 is made, it's a nice car, but like bathtub chassis better.
That belt driven car looks alright, but I prefer the shaft driven touring cars...
I heard that the belts will wear out eventually..[]
CA
WOW! [sm=omg_smile.gif] That is beautiful!
I've been holding off getting the TA05R because I'm waiting for the EBBRO BTEC Maziora 350R with the TA05IFS chassis, but now I'm thinking of picking up both! Have you run it yet? By the looks of it, it should have no problem hanging with the TRF cars.
CA
Ugh! Josh, lead me not into temptation! Must....be...strong.....must.....fight....Tamiya.. .addiction!!! [sm=cry_smile.gif]
for any CF addicts... not exactly a bargain though..
http://cgi.ebay.com/OPT0501-Xenon-Ra...QQcmdZViewItem
