What is the eyelet? I can't get mine off...?
I am doing misbehavin-rc's trick to streinghten my stock shocks. found here http://www.misbehavin-rc.com/pit-lan...hen-shocks.asp . it says to remove the eyelet to put on that fuel tubing... is the eyelet the think on the bottom? mine is hard to come off? do i hold the shaft with pliers and twist?
Please tell me if you don't think this upgrade is even worth it.. thanks
always dreamin
always dreamin
RE: What is the eyelet? I can't get mine off...?
i don't know, i rember i read somewhere to replace your shock shaft it was scratched.. i think i would scratch it if I held onto it with pliers[&:]....
let me know
always dreamin
let me know
always dreamin
NC
you can add an even longer peice of fuel tubing to prevent your truck from bottoming out. This allows you to run thinner shock oil for better off road handling, and you can still jump without the fear of breaking your truck.
